Add tables
With CorelDRAW, you can add a table to a drawing to create a structured layout for text and images. You can draw a table, or you can create a table from existing text.
In this example, a table was used to organize the content.
To add a table to a drawing
Click the
Table tool
![](../Shared_graphics/table.svg)
Type values in the
Rows and columns boxes on the property bar.
The value that you type in the top portion specifies the number of rows; the value that you type in the bottom portion specifies the number of columns.
Drag diagonally to draw the table.
![*](images/tip.svg)
You can also create a table by clicking Table
Create new table, and then typing values in the Number of rows, Number of columns, Height, and Width boxes.
To create a table from text
Click the
Pick tool
![](../Shared_graphics/pick.svg)
Select the text that you want to convert to a table.
Click
Table
Convert text to table.
4
In the
Create columns based on the following separator area, choose one of the following options:
Commas — creates a column where a comma appears and a row where a paragraph marker appears
Tabs — creates a column where a tab appears and a row where a paragraph marker appears
Paragraphs — creates a column where a paragraph marker appears
User defined — creates a column where a specified marker appears and a row where a paragraph marker appears
If you enable the
User defined option, you must type a character in the
User defined box.
![*](images/note.svg)
If you do not type a character in the User defined box, only one column is created, and each paragraph of text creates a table row.
You can also convert a table to text. For more information, see To convert a table to text.
