Attract or push away nodes to shape
The Attract and Repel tool lets you shape objects by attracting nodes or pushing nodes away. To control the shaping effect, you can vary the size of the brush nib and the speed at which the nodes are attracted or pushed away, and you can use the pressure of your digital pen.
Attracting nodes to shape an object
Pushing nodes to shape an object
To shape an object by attracting and pushing away nodes
Select an
object by using the
Pick tool
In the toolbox, click the
Do one of the following:
To attract nodes to the cursor, click the
Attract tool
on the property bar.
To push nodes away from the cursor, click the
Repel tool
4
Click inside or outside the object, close to its edge, and hold down the mouse button to reshape the edge. For a more pronounced effect, drag while holding down the mouse button.
Set the size of the brush nib
Type a value in the Nib size box on the property bar.
To change the size of the brush nib, you can also drag in the document window while holding down Shift. Drag towards the nib’s center to decrease the radius, and away from the nib’s center to increase it.
Set the speed at which nodes are attracted or pushed away
Type a value in the Rate box.
Use the pressure of a digital pen to control the effect
Click the Pen pressure button  on the property bar.
