Error logging and reporting
If an application in CorelDRAW Graphics Suite quits unexpectedly, an error report will appear the next time you launch the application. To help improve the application, provide any steps necessary to reproduce the problem, and send the error report to Corel. You can also disable error logging and reporting.
To enable or disable error logging and reporting
Back to Top
1 Click Tools Options Global.
2 In the left pane of the Options dialog box, click Privacy.
3 Enable or disable the Show Crash Report dialog box check box.
When the check box is disabled, you will not be prompted to send reports if the application stops responding.
