The Parallel Drawing mode allows you to simultaneously draw multiple parallel curves while controlling the distance between them. In addition, you can set the distance between the original line and the parallel line by specifying a value or dragging in the document.
CorelDRAW lets you create single or multiple parallel lines and preview them as you draw. You can hide the preview if you want to focus on the original line. You can also add parallel lines to an existing line.
From left to right: Parallel drawing with the 2-point Line tool, 3-Point Curve tool, and Pen tool
You can draw parallel curves simultaneously.
The Parallel Drawing mode is available for the following tools:
Type a value in the Distance box. You can also set the distance by clicking the Set distance interactively button |
You can also display the Parallel Drawing toolbar by clicking Window
Toolbars
Parallel Drawing.
