Print your work
Using CorelDRAW, you can print one or more copies of the same drawing. You can also specify the page type and the page range that you want to print.
Before printing a drawing, you can specify printer properties, including paper size and device options. For example, you can specify printer features such as duplexing stapling.
To set printer properties
Back to Top
1 Click File Print.
2 Click the General tab.
3 In the Destination area, choose a printer from the Printer list box.
4 Click the Printer preferences button .
5 Set any properties in the dialog box.
To print your work
Back to Top
1 Click File Print.
4 In the Destination area, choose a page size and orientation option from the Orientation list box.
5 In the Copies area, type a value in the Number of copies box.
If you want the copies collated, enable the Collate check box.
6 In the Print range area, enable one of the following options:
• Current document — prints the active drawing
• Current page — prints the active page
• Pages — prints the pages that you specify
• Documents — prints the documents that you specify
• Selection — prints the objects that you have selected
If you enable the Pages option, you can choose to print a range of pages, only even pages, only odd pages, or both even and odd pages.
You can also
Automatically match the printer orientation to the document orientation
In the Destination area, choose Match orientation from the Orientation list box.
Apply the printer’s default page size
In the Destination area, choose Use printer default from the Orientation list box.
You must select objects before printing a selection.
Certain printers support the automatic matching of page size and orientation. To enable this option, you need to modify the driver compatibility settings for the printer by clicking Tools Options Global and clicking Printing. Next, click Driver compatibility, and enable the Print to fit the paper size check box. In the Print dialog box, you can then choose Match orientation and size from the Orientation list box.
