View and print object data
The Object Data Manager, which is accessible from the Object Data docker, provides the commands and functions you need to view the data you’ve assigned to one or multiple objects in a drawing. While the Object Data Manager can be used to view and edit data associated with a single object, its main purpose is to help you view and manage large amounts of data associated with multiple objects contained in various groups.
You can change how object data is displayed:
You can set the number of nested group levels to show.
You can display individual group subtotals for fields shared by multiple groups. Use this command when more than one group of objects is displayed in a data sheet. This command applies only to fields with numeric formats.
To create a visible distinction between groups in a column, you can place a two-space indent before data relating to objects in groups.
You can have the
Object Data Manager automatically total the values in the selected column. The total is displayed at the bottom of the column.
The Object Data Manager gives you access to all of the application’s printing capabilities, so you can print quickly or print using specific settings.
To view and print an object data summary
Select the object or objects using the
Pick tool
If you want to view the object data summary for the entire document, click
Edit
Select all
Objects.
In the
Object Data docker (
Window
Dockers
Object Data), click the
Open spreadsheet button
The object data summary is displayed in the
Object Data Manager window.
Perform a task from the following table.
Set the number of nested group levels to display
Type a value in the Show levels box.
Display or hide group subtotals
Right-click the column title, and click Summarize Groups.
A check mark beside the Summarize Groups command indicates that the group subtotals are displayed.
Indent or align groups in a column
Right-click the column title, and click Show Hierarchy.
A check mark beside the Show Hierarchy command indicates that the nested groups in a column are indented.
Display or hide the sum of values in a column
Right-click the column title, and click Show Totals.
A check mark beside the Show Totals command indicates that the sum of the values in a column are displayed.
Print the object data summary
Click the Print button  . Choose a printer from the Printer list box. Type a number in the Number of copies box. For more information about the printing capabilities of CorelDRAW, see Print basics.
Tip: To set page margins and exclude gridlines, column headers, or row headers, click the Page Setup button, and choose the settings you want in the Page Setup dialog box.
