Your privacy and profile
Corel tracks which features you are using to improve the application. Also, when you search for learning materials from within the Learn docker, Corel tracks your searches and uses this information to improve the available learning materials and create new tutorials. You can adjust your privacy settings to opt out of feature and search term tracking at any time.
Once you complete your profile, we can recommend learning materials based on the information you provided in the survey, such as your familiarity with the product and the projects you create. If you don’t want to receive any recommendations, you can reset your profile to the default state. You can also edit your profile at any time by changing your responses and providing answers to newly added questions. An up-to-date profile helps us improve our recommendations for you.
To manage privacy settings
Back to Top
1 Click Tools Options Global.
2 In the left pane of the Options dialog box, click Privacy.
3 Perform a task from the following table.
To
Do the following
Allow or prevent Corel from tracking what features you use
Enable or disable the Share feature usage check box.
Allow or prevent Corel from collecting information about your searches in the Explore tab of the Learn docker
Enable or disable the Share search terms check box.
Note: Searching for learning materials in the Explore tab of the Learn docker is an application feature, so if you disable the Share feature usage check box, the Share search terms check box is disabled and grayed out by default.
To manage your profile
Back to Top
3 Click one of the following buttons:
Reset Profile — reverts your profile to the default state, letting you opt out of recommendations in the Welcome Screen and Learn docker
Edit Profile — opens the latest version of the profile survey, letting you update your responses and answer any new questions that may have been added
