Add bullets to text
To quickly add bullets to paragraph text
To add bullets
You can use bulleted lists to format information. You can wrap text around bullets, or you can offset a bullet from text to create a hanging indent. Corel DESIGNER lets you customize bullets by changing their size, position, and distance from text. You can also change the spacing between items in a bulleted list. For more information, see To adjust interline spacing.
Three paragraphs (left) were converted into a bulleted list (right)
You can remove a bullet without deleting the text.
To quickly add bullets to paragraph text Back to Top
To add bullets Back to Top
Enable the Preview check box.
In the Appearance area, choose a font from the Font list box.
Open the Symbol picker, and click a symbol.
Type a value in the Baseline shift box.
In the Spacing area, type a value in the Text frame to bullet box.
Type a value in the Bullet to text box.
Enable the Use hanging indent style for bulleted lists check box.
Select the bullet with the Text tool , and click a color on the color palette.
Click the Bulleted list button .
Bullets are inserted at the beginning of each new line that is preceded by a return.
You can adjust the spacing in between bullets by increasing or decreasing the space before and after a paragraph. For more information, see To adjust the spacing between paragraphs.
