Hatch fills can be used to indicate different materials.
Hatch fills are composed of vector-based lines. You can use preset hatch fills or edit fills by setting different line patterns and colors for the foreground, or by changing the color of the background. When you edit hatch fills in the Hatch fill dialog box, the changes apply only to the currently selected object. You can also create new hatch fills and add them to a library.
You can use hatch fills on projected objects to create the illusion of a three-dimensional image. Hatch fills use the active drawing plane.
Transforming and scaling hatch fills
The hatch fills are aligned in the drawing on the right.
| To apply a hatch fill |
| 1 . | Select an object for which you want to apply or edit a hatch fill. |
| 2 . | Click Edit |
| 3 . | In the Properties docker, click the Hatch fill button |
| 4 . | Click the Hatch fill properties button |
| 5 . | In the Edit fill dialog box, choose a hatch fill library from the Library list box. |
| 6 . | Choose a hatch fill from the Fill picker located below the Library list box. |
| If a hatch fill is already applied to the selected object, it appears in the Fill picker. |
| 7 . | Specify the attributes you want. |
Choose a color from the Front color picker.
Choose a color from the Back color picker.
In the Parameters area, type a value in the Spacing box. Larger numbers increase the distance between lines; smaller numbers decrease the distance.
In the Parameters area, type a value in the Thickness box. Larger numbers increase the line width; smaller numbers decrease the line width.
Type a value in the Skew box to set the degrees by which the lines are skewed.
Type a value in the Rotate box to set the degrees by which the lines are rotated.
When you edit a hatch fill in the Edit fill dialog box, the changes are applied only to the object selected in the drawing window. Only custom hatch fills created in the New hatch from selected dialog box can be added to a library.
You can also apply a hatch fill by clicking the Interactive fill tool in the toolbox, choosing Hatch fill from the Fill type list box on the property bar, and specifying the properties you want.
| To create a custom hatch fill |
| 1 . | Click Window |
| 2 . | In the Properties docker, click the Hatch fill button |
| 3 . | Click the Hatch fill properties button |
| 4 . | In the Edit fill dialog box, click New hatch. |
| The new hatch fill is based on the current fill. |
| 5 . | In the New hatch from selected dialog box, click a line to edit from the Hatch lines list. |
| The selected line is displayed in red in the Hatch preview window. Unselected lines are displayed in their applied color. |
| 6 . | In the Line style area, specify the attributes you want. |
| 7 . | In the Line origin area, specify the following: |
| • | y-Origin — lets you set the y-origin for the line. This setting is important if you have more than one line in the hatch fill. The y-Origin value can be used to set the spacing between different lines. For example, to ensure that a new line isn’t positioned directly over an existing line, type a new value in the y-Origin box. |
| • | x-Origin — lets you set the x-origin for the line. This setting is effective when you have more than one dashed line and you want to offset the patterns of the different lines. It has no visible effect on standard solid lines. |
| 8 . | In the Line angle box, type a value to set the angle of the line. |
| 9 . | In the Shift box, type a value to offset each instance of a line. |
| This setting is effective when you have one dashed line and you want to stagger the pattern. It has no visible effect on standard solid lines. |
| 10 . | Type a value in the Spacing box to set the distance between two instances of the line. |
| The distance between lines is set from the path for the line, not the edge of the outline. If the Outline width value is high and the Spacing value is low, the lines might overlap. |
| 11 . | Repeat steps 5 through 10 for each line you want to edit. |
| 12 . | Click OK to return to the Hatch fill dialog box, choose a library from the Library list box, and click Add to library. |
Click the Add button
In the Hatch lines list, choose a line, and click the Delete button
Hide or show lines in the Hatch preview window
In the Hatch lines list, click the Eye icon
| To scale or transform a hatch fill with an object |
| 1 . | Select an object. |
| 2 . | Click Edit |
| 5 . | In the Edit fill dialog box, enable the following options: |
| • | Transform with object — automatically transforms the hatch fill to reflect all future transformations applied to the object |
| • | Scale line width with object — automatically scales hatch lines when the object is resized |
| To align hatch fills across multiple objects |
| 1 . | Select two or more objects that have the same hatch fill. |
| 2 . | On the property bar, click the Fill button |
| 3 . | In the Edit fill dialog box, enable the Use world coordinates option. |
