Two-color pattern fills
To apply a two-color pattern fill
To create a two-color pattern fill
A two-color pattern fill is composed only of the two colors that you choose. In addition to specifying the colors, you can mirror the fill tiles vertically or horizontally, and you can set the size of the fill tiles. You can also skew and rotate the fill, and you can move its center.
A two-color fill applied to an object (left). Next, the fill is resized (middle), and rotated (right).
You can create your own pattern fill from objects in the drawing window by using the Object Create Pattern Fill command.
To apply a two-color pattern fill Back to Top
Click the Mirror tiles horizontally or the Mirror tiles vertically button.
Type values in the Fill width and Fill height boxes.
Type values in the X and Y boxes.
Click the Row offset or the Column offset button , and type a value in the % of tile box.
Enable the Transform with object check box.
Enable the Fill winding check box.
You can also mix colors in a two-color pattern fill by pressing and clicking a color on the color palette.
You can also drag colors from the color palette to the interactive handles to change the colors of the fill. You can mix colors by holding down while dragging a color to the interactive handles.
To create a two-color pattern fill Back to Top
