To draw an ellipse or a circle
To convert a curve to an ellipse
| To draw an ellipse or a circle |
| • | In the toolbox, click the circle or ellipse tool you want to use. |
Click the 3-point circle tool
Click the Center-point circle tool
Click the Center-radius circle tool
Click the 2-point ellipse tool
Click the 3-point ellipse tool
When you draw a circle, holding down the constrain key while dragging constrains the shape to the current constrain angle. See Constrain keys for more information. Holding down the constrain key while drawing an ellipse constrains the shape to a circle.
You can draw a two-point or three-point ellipse from its center outward by holding down the Shift key as you drag (if the constrain key is Ctrl).
| To convert a curve to an ellipse |
| 1 . | Select the curve object to convert. |
| 2 . | Click Object |
| To align an ellipse to a line |
| 1 . | Using the Pick tool, drag the ellipse by its center point and snap its center to the line. |
| 2 . | Click the ellipse to display the rotation handles. |
| 3 . | Select the quadrant node that is closest to the line, and move it until it snaps to the line. |
| To move an ellipse along its thrust axis |
| • | Using the Pick tool, drag the ellipse by its center while holding down W. |
Moving an ellipse along its thrust axis.
| To draw an arc or a wedge |
Click the Arc button
Click the Pie button
When you draw an arc, the ellipse or circle must have an outline.
You can change the direction of a selected arc or a wedge by clicking the Geometric properties button on the property bar and clicking Change direction button in the Properties docker.
