To import an encapsulated PostScript file
To export an encapsulated PostScript file
To set general exporting options
| • | You want text in the EPS file to be displayed with the original fonts, without any font substitutions. |
| • | You are working with a large EPS file, and you don’t want to slow down the application. |
During the CorelDRAW Technical Suite installation, you have the option of installing Ghostscript, which is an application that interprets the PostScript file format. Ghostscript allows you to import PostScript Level 3 files. If you did not install Ghostscript when you first installed the product, you can do so now.
| To import an encapsulated PostScript file |
| 1 . | Click File |
| 2 . | Locate the folder in which the file is stored. |
| 3 . | Choose PS, EPS, PRN - PostScript (*.ps; *.eps; *.prn) from the list box next to the File name box. |
| 4 . | Click the filename. |
| 5 . | Click Import. |
| 6 . | In the Import EPS dialog box, enable one of the following options: |
| • | Import as editable —brings in the file as a group of Corel DESIGNER objects that you can modify |
| 7 . | If you are importing the file as editable, enable one of the following text options: |
| • | Text — preserves text objects in the imported file so that you can edit the text |
| • | Curves — converts text to curves |
| 8 . | Click OK. |
| 9 . | Click the drawing page. |
Some restrictions apply when you modify EPS files imported as editable. For more information, see PostScript (PS or PRN) technical notes.
You can also drag an EPS file from Windows Explorer into the drawing window.
| To export an encapsulated PostScript file |
| 1 . | Click File |
| 2 . | Locate the folder in which you want to save the file. |
| 3 . | Choose EPS - Encapsulated PostScript from the Save as type list box. |
| 4 . | Type a filename in the File name list box. |
| 5 . | Click Export. |
| 6 . | In the EPS export dialog box, adjust any of the settings. |
| To set general exporting options |
| 1 . | In the EPS export dialog box, click the General tab. |
| 2 . | Perform one or more tasks from the following table. |
In the Color management area, choose an option from the Output colors as list box:
If you choose the Native option, all objects preserve the color mode in which they were created, for example RGB, CMYK, Grayscale, or spot.
In the Color management area, enable the Convert spot colors to check box, and select an option from the list box.
In the Preview image area, choose one of the following options from the Type list box:
Enable one of the following options in the Export text as area:
If you want to include PostScript font information with your file, enable the Include fonts check box.
From the Compatibility list box, choose a PostScript level that is supported by the printer or the application with which you will be printing or displaying the file.
Objects are always output as CMYK. Bitmaps have the option of different color modes.
If you choose the 8-bit TIFF format for previewing images, you can make the background of the bitmap transparent by enabling the Transparent background check box in the Preview image area.
| To set advanced exporting options |
| 1 . | In the EPS export dialog box, click the Advanced tab. |
Type a name in the Author box.
In the Bitmap compression area, enable the Use JPEG compression check box. Move the JPEG quality slider to adjust the quality of the bitmaps.
In the Trapping area, enable any of the following options:
If you want to specify the minimum font size to which Auto-Spreading is applied, type a value in the Text above box.
If you want the outlines of all objects on the page to have the same width, enable the Fixed width check box.
In the Bounding box area, enable any of the following options:
Enable the Maintain OPI links check box to use low-resolution images as placeholders for high-resolution images.
The Use JPEG compression check box remains disabled until you choose a PostScript level that supports this feature.
| To install Ghostscript |
| 1 . | Close any open programs. |
| 2 . | On the Windows taskbar, click Start |
| 3 . | Click Uninstall a program. |
| 4 . | Double-click CorelDRAW Technical Suite from the Uninstall or change a program page. |
| 5 . | Enable the Modify option. |
| 6 . | On the Features page, enable the GPL Ghostscript check box. |
| 7 . | Follow the instructions in the installation wizard. |
| Encapsulated PostScript (EPS) technical notes |
| • | If the encapsulated PostScript file was imported with the Place as Encapsulated PostScript option, and if it contains a preview image (called a header), the preview image is imported and displayed. The EPS information remains attached to the header and is used when the image is printed to a PostScript printer. |
| • | The PostScript Interpreted filter converts the objects in the encapsulated PostScript file to native Corel DESIGNER objects on import. |
| • | When you import a file with large or complex gradient fills, you may generate a large number of objects. |
| • | On a PostScript printer, graphics exported to the encapsulated PostScript (EPS) format print from other programs exactly as they do from a Corel graphics programs. |
| • | You can save a header to the Tagged Image file format (TIFF) or Windows Metafile format (WMF) in black and white, 4-bit grayscale or color, or 8-bit grayscale or color. You can set the header resolution between 1 and 300 dots per inch (dpi); the default header resolution is 72 dpi. If the program importing the EPS file has a limitation on the image header size, you might receive an error message stating that the file is too large. To reduce file size, in the EPS export dialog box, choose Black and White from the Mode box, and lower the header resolution before exporting the file. The setting determines only the resolution of the header and has no impact on the print quality of a drawing. Color headers are useful for viewing EPS files. If the program in which you are going to use the file does not support color headers, try exporting with a mono header instead. You can also export without a header. |
| • | Along with the graphic, exported EPS files contain a filename, program name, and date. |
| • | To save font information in an EPS file, enable the Include fonts check box in the Export text as area. |
| • | If you export text as curves, text is converted to vector curves. |
| • | If a font used in the file is not available on the printer or has not been saved in the file, either the text is printed in Courier font or the drawing is not printed. |
