Find, edit, and convert text
To find text
To find and replace text
To find and replace text properties
To edit text
To convert text
You can find text in a document and replace it automatically. You can also find and replace the properties of text objects. You can find special characters, such as an em dash or optional hyphen. You can edit text directly in the drawing window or in a dialog box.
Corel DESIGNER lets you convert artistic text to paragraph text if you require more formatting options, and paragraph text to artistic text if you’d like to apply special effects.
You can also convert both paragraph and artistic text to curves. By transforming characters into lines or curve objects, you can add, delete, or move the nodes of individual characters to alter their shape. For more information, see Curve objects.
When you convert text to curves, the appearance of the text is preserved, including font, style, character position and rotation, spacing, and any other text settings and effects. Any linked text objects are also converted to curves. If you convert paragraph text in a fixed-sized text frame to curves, any text that overflows the text frame is deleted. For information about fitting text to a text frame, see Format text.
To find text Back to Top
You can also find special characters by clicking the right arrowhead next to the Find box, choosing a special character, and clicking Find Next.
To find and replace text Back to Top
To find and replace text properties Back to Top
To edit text Back to Top
Text that has been converted to curves cannot be edited.
You can also edit text by clicking Text Edit Text, and making changes to the text in the Edit Text dialog box.
To convert text Back to Top
Using the Pick tool , select the text, and click Text Convert to Artistic Text.
Using the Pick tool , select the text, and click Text Convert to Paragraph Text.
Using the Pick tool , select the text, and click Object Convert to Curves.
Paragraph text cannot be converted to artistic text when it’s in a linked frame, has text overflow, or has special effects applied to it.
You can also convert text to curves by clicking the Pick tool , right-clicking the text, and clicking Convert to Curves.
