After creating all the data fields you want for a drawing, you can create a database from a template. The database stores all the data you apply to the objects in your drawing. You can choose from three different templates; because each template saves to an external, tagged XML file, you can store the data for different workflows simultaneously.
The Object Data docker provides all the commands and features you need to add, edit, and delete object data — even behaviors that were applied using the Internet toolbar.
Corel DESIGNER also provides common ActiveCGM, WebCGM, and WebCGM S1000D fields. When you import or export CGM files, the object data is maintained. For more information on importing and exporting CGM files, see Computer Graphics Metafile (CGM).
Object data is also maintained when you import or export SVG files. For more information about importing and exporting SVG files, see Scalable Vector Graphics (SVG).
| To choose a database template |
| 1 . | Click Window |
| 2 . | From the list box, choose one of the following templates: |
| • | General |
| • | ActiveCGM |
| • | S1000D issue 4.0 |
| • | WebCGM |
You can also view all existing database entries by choosing All from the list box.
| To add or edit data for an object |
| 1 . | Select the object using the Pick tool |
| 2 . | Click Window |
| 3 . | Select a data field. |
| A check mark indicates whether that field is applied to the selected object. |
| An icon indicates the field type: |
| • | Text |
| • | Number |
| • | Action |
| • | Event |
| 4 . | Type text in the Value column for the field, and press Enter. |
| 5 . | Double-click in the Constraint column for the field, and specify a constraint value in the Object data field editor dialog box. |
| 6 . | Repeat steps 3 to 5 to add data to other fields. |
Click the Show/hide behaviors button
Click the Show/hide data button
Click the Show active fields only button
Click the Copy data from button
Click the Clear all fields button
