You can also use the installation wizard to do the following:
Repairing an installation is helpful when you encounter problems in using the application, or when you suspect that the installation is corrupt.
Before repairing an installation, try resetting the current workspace to the default settings by holding down F8 while starting the application. Note that when you reset the workspace, all workspace preferences are reset.
| 4 . |
Enable the Modify option or the Repair option in the wizard that appears, and follow the instructions. |
Program features and utilities that are already installed may not appear in the wizard, or their check boxes appear disabled.
Certain features, such as Copy installation files and Install desktop shortcuts, cannot be added by modifying your installation.
