Corel DESIGNER lets you size and scale objects. In both cases, you can change the dimensions of an object proportionally by preserving its aspect ratio. You can size an object by specifying values or changing the object interactively. Scaling changes an object’s dimensions by a specified percentage.
You can also specify a rectangular area for selected objects to scale into.
| To specify the size of an object |
| 1 . | Select an object. |
| 2 . | Click View |
| 3 . | Type values in the Object size boxes on the Transform toolbar. |
Click the Relative to object button
Size an object by using the Transform docker
Clicking Object
You can also set the width or height of the object interactively by clicking the Set dimensions interactively button
In the Transform docker, enable the Proportional check box.
In the Transform docker, click the point on the origin locator
that corresponds to the point on the object from which you want to size the object. |
In the Transform docker, type a number in the Copies box.
| To size an object interactively |
Hold down Shift, and drag one of the selection handles.
Hold down Ctrl, and drag one of the selection handles.
Hold down Alt, and drag one of the selection handles.
You can set a precise size for the object by clicking the Geometric properties button on the property bar and typing values in the Properties docker.
| To scale an object |
| 2 . | Click the Shape tools button in the toolbox, and click the Free transform tool |
| 3 . | Click the Free scale button |
If you want to change the reference point to use when scaling the object, locate the Object origin icon on the property bar and click the box that corresponds to the reference point you want to set. |
| 4 . | On the property bar, type values in the Scale factor boxes to specify a percentage by which to scale the object horizontally or vertically. |
| If you want to maintain the aspect ratio, click the Lock ratio button |
Scale an object by using the Transform docker
Click Object
In the Transform docker, enable the Fit to box option. Click Apply, and drag in the drawing window to specify the rectangular area.
that corresponds to the point on the object from which you want to scale the object. |
You can also scale an object by dragging a selection handle.
You can also scale an object by typing values in the Scale factor boxes on the Transform toolbar. To display the Transform toolbar, click View
Toolbars
Transform.
