Most of the symbols you need have already been created and are stored in library files that are grouped into collections.
The Symbols docker always displays libraries and collections that are in your local Symbols folder. You can add collections and libraries to your Symbols folder from elsewhere on the network. The symbols that are used within the document appear under the document filename in the Symbols docker.
You can add libraries and collections (groups of library files) to your drawing. You can also delete libraries and collections.
| 1 . |
Click Window Symbols. |
| 2 . |
In the Symbols docker, click Local symbols or Network symbols. |
| 3 . |
Click the Options button , and click Import library. |
By default, library files are referenced from their original location. If you want to copy a library to your Symbols folder, enable the Copy libraries locally check box.
If you are adding a collection, you can enable the Recursive check box to include subfolders.
The collection or library is removed from the tree in the Symbols docker but files are not deleted.
