Customize workspace appearance
To change the workspace appearance
To specify a window or desktop color by using various color tools
You can customize the size of user interface items, choose a theme, and change the color of window borders and the desktop.
Center dialog boxes
By default, all dialog boxes appear centered in the application window. However, you can position a dialog box where you want all dialog boxes to appear, and then disable the Center dialog boxes setting. The next time you open a dialog box, it will appear in your preferred location on the screen.
Scaling
You can change the size of user interface (UI) items by changing the scaling level. The scaling level is relative to the scaling level of the operating system. The default setting is 100%, which means that UI items in the application appear the same size as similar UI items in the operating system. Scaling by 200% makes the application UI items appear twice as large as the UI items of the operating system.
Theme
To make the workspace lighter or darker, you can choose one of the following themes: Light, Medium, Dark, or Black.
Window border color
You can customize the application window and dialog boxes by changing the color of their borders.
Desktop color
You can change the color of the desktop, the area surrounding the drawing page, to suit your documents. For example, if the document contains dark colors, you can change the desktop color from white to gray for lower contrast.
Choose colors
To choose the color you want for the desktop and window borders, you can quickly sample any onscreen color; or you can use color sliders, color viewers, or color palettes.
Various tools are available to help you change the desktop or window border color.
To change the workspace appearance Back to Top
To specify a window or desktop color by using various color tools Back to Top
Click the Color eyedropper tool , and click an onscreen color.
Click the Show color sliders button , choose a color mode from the list box, and move the sliders.
Click the Show color viewers button , choose a color mode from the list box, and click a color on the color viewer.
Click the Show color palettes button , choose a color palette from the Palette Libraries, and click a color.
Click the More color options button , and choose an option. The options are dependent on the selected method such as sampling or using a color viewer, color sliders or a color palette.
