Soften the edges of vector objects by using the Feather effect.
| To feather the edges of an object |
| 1 . | Select an object. |
| 2 . | Click Effects |
| 3 . | Type a value in the Width box. |
| 4 . | Enable one of the following options to specify the transparency gradient you want to use: |
| • | Curved — results in small transparency increments at the beginning of the feathered edge, larger transparency increments in the middle, and small transparency increments at the end |
| • | Linear — changes the edge transparency in even increments from the beginning to the end of the feathered section |
| • | Gaussian — blurs object edges outward according to Gaussian distribution, using bell-shaped curves |
| To preview your design while adjusting the effect settings, enable the Preview check box. |
