Size and scale objects
Corel DESIGNER lets you size and scale objects. In both cases, you can change the dimensions of an object proportionally by preserving its aspect ratio. You can size an object by specifying values or changing the object interactively. Scaling changes an object’s dimensions by a specified percentage.
Objects are sized or scaled from the object’s origin. You can change an object’s origin from its center to any one of its eight selection handles.
You can also specify a rectangular area for selected objects to scale into.
To specify the size of an object
Back to Top
1 Select an object.
2 Click View Toolbars Transform.
3 Type values in the Object size boxes on the Transform toolbar.
You can also
Apply the sizing according to the object’s position rather than the x and y coordinates
Click the Relative to object button on the Transform toolbar.
Size an object by using the Transform docker
Clicking Object Transform Size, and type values in the W and H boxes to set the width and height of the object.
You can also set the width or height of the object interactively by clicking the Set dimensions interactively button next to the W or H box and dragging in the drawing window.
Preserve the original ratio of width to height when transforming the object
In the Transform docker, enable the Proportional check box.
Size from a point on the selected object
In the Transform docker, click the point on the origin locator that corresponds to the point on the object from which you want to size the object.
Leave the original object unchanged and apply the transformation to copies that are created
In the Transform docker, type a number in the Copies box.
To size an object interactively
Back to Top
• Perform a task from the following table.
To
Do the following
Size a selected object
Drag any of the corner selection handles.
Size a selected object from its center
Hold down Shift, and drag one of the selection handles.
Size a selected object to a multiple of its original size
Hold down Ctrl, and drag one of the selection handles.
Stretch a selected object as you size it
Hold down Alt, and drag one of the selection handles.
You can set a precise size for the object by clicking the Geometric properties button on the property bar and typing values in the Properties docker.
To scale an object
Back to Top
1 Select an object.
2 In the toolbox, click the Free transform tool .
3 Click the Free scale button on the property bar.
If you want to change the reference point to use when scaling the object, locate the Object origin icon on the property bar and click the box that corresponds to the reference point you want to set.
4 On the property bar, type values in the Scale factor boxes to specify a percentage by which to scale the object horizontally or vertically.
If you want to maintain the aspect ratio, click the Lock ratio button on the property bar.
You can also
Apply the scaling according to the object’s position rather than the x and y coordinates
To open the Transform toolbar, click View Toolbars Transform.
Scale an object by using the Transform docker
Click Object Transform Scale and mirror, and type values in the X and Y boxes to scale the object horizontally or vertically.
Specify a rectangular area into which to scale the object
In the Transform docker, enable the Fit to box option. Click Apply, and drag in the drawing window to specify the rectangular area.
Scale from a point on the selected object
In the Transform docker, click the point on the origin locator that corresponds to the point on the object from which you want to scale the object.
You can also scale an object by dragging a selection handle.
You can also scale an object by typing values in the Scale factor boxes on the Transform toolbar. To display the Transform toolbar, click View Toolbars Transform.
