Work with linked assets
When you find the symbol library you need, you can link it to the document so that it is available for use. The Linked assets view in the Assets docker lets you access the symbol libraries that are linked to the active document. If the symbol libraries are linked from the Cloud, you can refresh the file list to sync it with your Cloud folder.
You can open your linked symbol libraries for editing, but not linked libraries that are shared with you. You can also sync linked libraries with the source so that their symbols are always up-to-date.
Linked assets view
The Symbols docker lets you access the symbols in a linked library form the Linked Symbols section so you can use them in your projects. For more information, see Use symbols in drawings.
To link a symbol library to the active document
In the
Assets docker (
Window
Assets), click a symbol library.
Click the
Import button
, and click
Link to document.
You can also right-click a symbol library, and click Link to document.
To work with linked symbol libraries
In the
Assets docker (
Window
Assets), click the
Linked assets button
Perform a task from the following table.
Refresh the list of libraries linked from the Cloud
Click the Refresh List button  .
Edit a linked symbol library
Right-click a thumbnail, and click Edit.
Note: The Edit command is not available for symbol libraries that are shared with you.
Sync a linked symbol library
Right-click a thumbnail, and click Sync linked assets.
Note: The Sync linked asset command is only available when the source file has been updated.
Break the link of a linked symbol library
Right-click a thumbnail, and click Break link.
Note: The linked asset is removed from the document.
