Print merge
Corel DESIGNER lets you combine text from a data source with a drawing. When you merge documents, you can produce several different copies of a drawing. You can use merged documents to create personalized documents, such as mailing lists, questionnaires, and targeted marketing documents, where each printed document contains specific information from a record in a data source, such as a text file or an ODBC data source (a Microsoft Excel or Microsoft Access file).
When you merge documents, you create a form document in Corel DESIGNER and combine it with a data source. A form document provides the pattern and layout for a merged document. A data source supplies information for a drawing during the merge. Corel DESIGNER supports the following data source files: Text (TXT) files, comma-separated values (CSV) files, Rich Text Format (RTF) files, and files that can be opened by means of an ODBC data source.
Data source document (1), form document (2), and merged documents (3)
Creating a data source file
Information in a data source file is organized into fields and records. A field can contain one or more characters. Fields can contain alphanumeric data or only numeric data. For example, a record may include a first name, last name, address, and other contact information. Each item within the record, such as first name, last name, or address, is recognized as a field. A record can contain one or more fields.
You can create a data source file or import an existing one. You can create a data text file by using Corel DESIGNER or a text editor. You can edit the data in a data source file at any time.
Creating a form document
Creating form documents is similar to creating regular drawings. For form documents, however, you insert merge fields, which are replaced by information from the data source during the merge.
Associating a form document with a data source file
When you use Corel DESIGNER to create a data file, or when you import an existing data file into Corel DESIGNER, the data file is associated with the form document. The association is always stored with the document and cannot be changed.
Performing a merge
Corel DESIGNER provides different output options for merge documents. You can print a merge document or save it to a new document. When you print a merge document, the form document is merged with the data source file during printing. When you save the merged document to a new file, the application merges the form document with the data from the data source file in a new Corel DESIGNER file. You can use this file to preview your final output and make minor adjustments before printing. For major changes, such as the addition or repositioning of merge fields or the addition of new records, you must work in the form document.
To create a data source file by using Corel DESIGNER
Back to Top
1 Click File Print Merge Create/load Print Merge.
2 In the Print Merge dialog box. click Add Column.
3 In the Add Column dialog box, type a column name in the Name box, and then do any of the following:
• To create a text field, enable the Text option, type a field name, and then click Add,
• To create a numeric field, enable the Numeric option, type a field name, and then click Add. In the Numeric fields options area, you can apply formatting to the data in a numeric field by choosing a format from the Format list box, and automatically increment the value in a numeric field by enabling the Continually increment value check box and specifying starting and ending values in the corresponding boxes.
Repeat this step for each field in the merge.
4 Click the Add a record button , and type data in the fields corresponding to that record.
Repeat this step for each record in the merge.
5 Click Save Data Source.
6 In the Save As dialog box, type a filename, choose the drive and folder where you want to save the file, choose a file format, and click Save.
You can also
Edit a field column
Click a field in the list, and click Edit Column.
Delete a field column
Click a field in the list, and click Delete Column.
Delete a record
Click a record, and click the Delete a record button .
View records
Click one of the following:
• View All Records — lets you display all records in a source data file
• View Single Record — lets you display the selected record
Browse records
Click any of the following buttons:
• First record
• Next record
• Previous record
• Last record
Go to a specific record
Type the record number in the Go to Record box, and click Go to Record.
Different numeric formats are available in Corel DESIGNER. For example, the X.0 format represents the value 1 as 1.0; the 00X format represents the value 1 as 001.
To create a data source by using a text editor
Back to Top
1 Open a text editor, and create a new file.
2 On the first line, type the number of merge fields that you want to insert in the drawing. For example:
3 On the second line, type the names of the merge fields by separating them with a backslash. Each merge field must begin and end with a backslash. For example:
\Name\\Date\\Instructor\
4 On the next lines, type the data that you want to appear in the merged document. Each line constitutes a record. For example:
\Pixie Parsons\\6 September 2021\\Mr. Randy Harris\
\Shirley Wilkinson\\13 January 2021\\Ms. Corinne Pitts\
5 Save the file as an ANSI text file (.txt extension) or as an RTF file.
Backslashes function as markers to indicate the beginning and end of merge fields; therefore, you cannot use them as data in fields.
Data in fields must end with a character. Blank spaces or lines before backslashes prevent the merge from being completed successfully.
To import a data source file
Back to Top
2 In the Print Merge dialog box, click the Import File.
3 In the Open dialog box, navigate to the drive and folder where the data file is stored.
4 Choose a file.
5 Click Open.
To import an ODBC data source file
Back to Top
2 In the Print Merge dialog box, click Open ODBC Data Source.
3 In the Select Data Source dialog box, do one of the following:
• Click the File Data Source tab, and select the file data source that describes the drive that you wish to connect to. You can use any file data source that refers to an ODBC driver that is installed on your machine.
• Click the Machine Data Source tab, under Data Source Name, select a data source type, and click OK.
4 Choose the database that you want to import, and click OK.
To create a form document
Back to Top
1 Open a drawing in which you want to insert merge fields.
2 Click File Print Merge Create/load Print Merge.
3 In the Print Merge dialog box, select or create a data source file.
4 Click Finish.
5 In the Print Merge docker, choose a field name from the Fields, and click Insert Field.
Corel DESIGNER places the merge field in the center of the current view. If you want to reposition the merge field, drag it to a new location on the drawing page.
6 Repeat step 5 to insert additional fields.
To perform a merge and print the document
Back to Top
1 In the Print Merge docker, click one of the following:
• Click Merge to New Document, and click Print.
• Click Perform Print Merge and click Print.
2 Specify any printer settings.
3 Click Print.
If you want to print all records and pages, enable the Current document option.
To perform a merge and save the document to a new file
Back to Top
You can also perform a merge and save the document to a new file by clicking Merge to new document on the Print merge toolbar.
