Note that Corel Content Exchange — the online storage for content accessible from earlier versions of the suite — is no longer available. Users can download content packs from the Get More page of the Welcome screen when working in online mode. However, we recommend that you make the content available to them on a network drive to facilitate their work.
The Proof of Entitlement Certificate email will contain a URL linking to a shared drive containing the extra content, which you can download. After you unzip the extra content to the location you want, you can create aliases to the various content folders from within Corel DESIGNER or CorelDRAW. When you create aliases, a database file is created. To make it easier for users to find and search the extra content, you must deploy this database file to the workstations.
The extracted content is 5.75 GB.
Internet access is required to access the download location.
When all zip files have been downloaded and decompressed, you should see the following folders:
Once the content is available on the server, users can create aliases to the folders so that they can access the content from within the Assets docker (formerly known as CONNECT Content docker), the Fill and Transparency pickers, and the New from Template dialog box in Corel DESIGNER or CorelDRAW. However, we recommend that you create the aliases yourself so that it is easier for users to access extra content.
You can create an alias to the Images folder as well. Note, however, that it takes a long time to generate the thumbnails of all images. That’s why we recommend that you create aliases to the subfolders.
To share content (fills, templates, and images) created by your company with the workstations, you can use the same method of creating aliases to network folders from within Corel DESIGNER or CorelDRAW.
When you create aliases, a simple database file is generated. This file is called UserCollections.db and resides in the following location:
After you deploy the content database file to the workstations, users will be able to search and use content from the alias folders.
