Deploying specific languages
When performing a basic or silent installation with the /q switch (see /q - Push the server image to the workstations), you may want to use the ADDLOCAL property to specify which software languages to support. You can specify a single language:
ADDLOCAL=Feature1,LanguageCode
Or you can specify a comma-separated list of languages:
ADDLOCAL=Feature1,LanguageCode1,LanguageCode2
Using language codes, you can specify language modules.
If you use the ADDLOCAL property in your command line to specify only languages, you will exclude all other product features. Consider using the ADDLOCAL property together with REMOVE to install all features and exclude specific languages:
ADDLOCAL=ALL REMOVE=LanguageCode1,LanguageCode2
Language codes are case-sensitive.
Specifying UI modules by language code
A language module includes the software UI. By installing multiple language modules, you can enable dynamic language switching — the ability to change the language of the software UI.
XVL Studio Corel Edition and XVL Player support only German (DE), English (EN), French (FR), and Japanese (JP).
The following table lists the available language modules for the software, along with their corresponding language codes.
Language module
Language code
Brazilian Portuguese
BR
Chinese (Simplified)
CS
Chinese (Traditional)
CT
Czech
CZ
Dutch
NL
English
EN
French
FR
German
DE
Italian
IT
Japanese
JP
Polish
PL
Russian
RU
Spanish
ES
Swedish
SV
Turkish
TR
By default, writing tools are automatically installed for all available languages.
