Getting to know the software
Make sure that your server and workstations are eligible for the software. If your organization uses a document-management system (DMS), make sure that it is supported by the software.
Server requirements
You can create an image of CorelDRAW Technical Suite on a server that meets the following requirements:
Operating system with the latest service pack and critical updates: Windows Server 2022
4.39 GB of server space (for a typical installation without extra content)
The supported server operating systems support Remote Desktop Services (RDS) (previously known as Windows Terminal Server), but please note the following:
You must use the CorelDRAW Technical Suite ISO file provided by Corel to install the software on the server.
Corel Corporation does not provide technical support for installing third-party software included with the product.
When you use remote desktop virtualization and deploy CorelDRAW Technical Suite on a server, note the following:
When you access the suite as an administrator, the security settings of your web browser on the server may not allow you to use the Welcome screen. By default, some web browsers have the Enhanced Security Configuration setting enabled. You must disable it for the Welcome screen to work normally.
By default, hardware acceleration is enabled. In virtualized environments, users must turn it off by disabling the
Use hardware acceleration check box (
Tools
Options
Global
General page). Hardware acceleration can also be disabled by setting the following registry key to 0:
[HKEY_CURRENT_USER\SOFTWARE\Corel\Corel DESIGNER\25.0\Box Preferences\GlobalOptions GeneralTab] "GPUAcceleration"="0"
Workstation requirements
You can install CorelDRAW Technical Suite on workstations that meet the following requirements:
Windows 11 or Windows 10 (Version 21H2 or later), 64-bit, with latest Updates
OpenCL 1.2-enabled video card with 3+ GB VRAM (recommended)
Intel Core i3/5/7/9 or AMD Ryzen 3/5/7/9/Threadripper, EPYC
9 GB of hard-disk space for application and installation files
Multi-touch screen, mouse or tablet
1280 x 720 screen resolution at 100% (96 dpi)
For optimal performance, ensure you have the latest device drivers provided by the manufacturer.
Internet connection is required to install and authenticate CorelDRAW Technical Suite and access some of the included software components, online features and content.
WebView2, the Microsoft Edge web control, is required to use Corel Cloud and the Comments docker. If this control is missing from the workstations, it will be installed during deployment.
For details on workstation permissions, see Workstation setup.
XVL Studio Corel Edition is included and installed with CorelDRAW Technical Suite. The advanced level XVL Studio 3D CAD Corel Edition is included in CorelDRAW Technical Suite 3D CAD Edition. For processing 3D CAD assembly data we recommend:
1280 x 800 or higher screen resolution
Internet connection required for product activation and installing updates
Software
CorelDRAW Technical Suite applications are available as an ISO file that you can download.
To use an ISO file, you can do one of the following:
Mount the ISO file as a virtual drive.
Extract the ISO file contents by using WinZip or other third-party software.
Optionally, other content is available for download from a shared drive. This content includes Corel AfterShot HDR, images (vector files and photos), fills, fonts, and templates.
The default installation of CorelDRAW Technical Suite offers a limited number of fills and transparencies so it is important to download and install the fill packs included in the Fills folder.
For more information, see Server setup.
Note that training videos are not available for download. You can access Hints videos and other videos on the CorelDRAW and CorelDRAW Technical Suite YouTube channels, or from the Welcome screen in CorelDRAW, Corel DESIGNER, and Corel PHOTO-PAINT.
For important notes on installing and using the software, it’s a good idea to review the Readme file for the software.
To access the Readme file on the installation disc
Run the following command line (where X: is the disc drive):
X:\ReadMes\EN\Readme.html
Readme files for other languages can be accessed from their respective language folders on the DVD or the software ISO. Examples:
X:\ReadMes\DE\Readme.html
X:\ReadMes\FR\Readme.html
X:\ReadMes\JP\Readme.html
