Stored in the Setup folder, the main Microsoft Windows Installer (MSI) file for the setup — \x64\msis\Setup_x64.msi — contains a database of main features, registry keys, folders, and shortcuts for the software.
The server image contains a copy of the main setup MSI file — the MSI tables within which you can modify for deployment to the workstations.
Various components of the software are stored in additional MSI files. Some of these MSI files are required by the setup, while others represent optional features of the software.
Besides Setup_x64.msi, the setup requires an addition MSI file to carry out the installation: x64\ICA_x64.msi.
The setup requires at least one language module, MSI files for which are stored at x64\msis (64-bit) on the installation disc. XVL Studio Corel Edition and XVL Studio 3D CAD Corel Edition support only German (DE), English (EN), French (FR) and Japanese (JP). However, some versions of CorelDRAW Technical Suite may include additional language modules for the remaining components (CorelDRAW and Corel PHOTO-PAINT). The following table lists all language modules that the software may contain.The language modules that are available vary with each edition of the software.
To install the programs included with the software, the setup uses the following MSI files at X:\x64\MSIs on the installation disc.
To install the various components of the software, the setup uses additional MSI files stored at Setup\x64\msis on the software ISO file or in the \MSIs folder of the server image. These files include the following.
You can exclude optional MSI files from the setup by creating a customized server image. Excluding an MSI file prevents the corresponding feature from being installed.
To install local Help for Corel DESIGNER, CorelDRAW, Corel PHOTO-PAINT, Corel Font Manager, CAPTURE, and Corel BARCODE WIZARD, the setup uses Documentaton_x64.msi, which is stored at Setup\x64\msis on the CorelDRAW Technical Suite 2024 DVD, the software ISO file, or in the \MSIs folder of the server image:
Local Help is installed to the following Help folder on the workstations:
