Assign keyboard shortcuts to styles or style sets
You can assign a keyboard shortcut to a style or style set. When you press the keyboard shortcut, Corel DESIGNER applies the style or style set to the selected object. A keyboard shortcut can use up to four different keystrokes.
If a keyboard shortcut is already assigned to another command, you can override the existing setting.
To assign a keyboard shortcut to a style or style set
Click
Window
Object Styles.
In the
Object Styles docker, right-click a style or style set, and click
Assign Keyboard Shortcut.
The
Options dialog box opens with the
Shortcut keys tab of the
Commands page displayed and
Apply styles in the top list box selected.
Select the style or style set to which you want to assign a shortcut.
If you have already assigned a keyboard shortcut to the selected style, the shortcut is displayed in the
Current shortcut keys box.
4
Click in the
New shortcut key box, and press a key combination.
If the key combination is already assigned to another command, that command is listed in the
Currently assigned to box.
If the same keyboard shortcut is already assigned to another command, the second assignment overwrites the first. By enabling the Navigate to conflict on assign check box, you can automatically navigate to the command whose shortcut you reassigned and assign a new shortcut.
