Change character position and angle
You can modify the appearance of text by shifting the characters vertically or horizontally, which changes the position of the selected characters relative to the surrounding characters.
You can also rotate characters by specifying an angle of rotation.
Examples of rotating text
To shift a character
Using the
Text tool
, select a character or a block of text.
If the
Properties docker is not open, click
Window
Properties.
In the
Properties docker, click the
Character button
to display the character-related options.
In the
Character area of the
Properties docker, click the arrow button
located at the bottom of
Character area to display additional options.
4
Perform one or more tasks from the following table.
Shift characters horizontally
Type a value in the Horizontal character offset box.
Shift characters vertically
Type a value in the Vertical character offset box.
To rotate a character
Using the
Text tool
If the
Window
Properties.
In the
Character button
In the
4
Type a value in the
Character angle box.
