Corel DESIGNER (DES, DSF, DS4, or DRW)
You can import Corel DESIGNER files. Files from version 10 and later have the filename extension .des. Files from Micrografx versions 6 to 9 have the filename extension .dsf. Version 4 files have the filename extension .ds4. The .drw filename extension is used for a Micrografx 2.x or 3.x file. Micrografx template files (DST) are also supported.
To import a Corel DESIGNER file
Back to Top
1 Click File Import.
2 Locate the folder in which the file is stored.
3 Choose DES - Corel DESIGNER (*.des) or DSF, DRW, DST, MGX - Corel/Micrografx Designer (*.dsf; *.drw; *.ds4) from the list box next to the File name box.
4 Click the filename.
5 In the Import dialog box, adjust any of the settings.
6 Click Import.
7 Click the drawing page.
Corel DESIGNER (DSF) technical notes
Back to Top
• Guidelines are preserved. Grid settings are not converted, however.
• Snap points are not converted — the program preserves the default gravity settings.
• Objects on some pages may be grouped together. You may want to select the group and then ungroup it before editing.
• DSF files display OLE data as picture objects. OLE data object types are lost in the conversion.
• Curvygons are converted to curves.
• Any part of a graphic that is outside the extents that Corel DESIGNER can support cannot be accessed. You should resize the graphic before converting.
• Enhanced line styles are preserved.
• Gradient transparency may be offset in some cases.
• Hatch fills are preserved in the imported file.
• Unclosed, filled lines are converted to two objects: one for the line and one for the fill.
• Block text in Corel DESIGNER 9 files is converted to paragraph text in Corel DESIGNER. Freeform text is converted to artistic text.
• Warped text is converted to curves.
• Repelled text (block text that wraps around an object) is converted to multiple text objects.
• Each line of a nonrectangular text object (text placed within an object) is converted to a separate text object.
• For block text that has many transformations, tab stops may stretch or shrink.
• Text flowing between containers is not preserved; each container is converted to a separate object.
• Dimensions of text in small caps vary when the text is imported.
Corel DESIGNER (DES) technical notes
Back to Top
• Dimension lines and connector lines are converted to curves when you save a file to Corel DESIGNER version 15.0 or earlier.
