CorelDRAW.app, Corel DESIGNER, and Cloud
Available exclusively to CorelDRAW Graphics Suite and CorelDRAW Technical Suite users, CorelDRAW.app is a web-based application for creating vector graphics. Access it from any device to capture your ideas into designs instantly or share your designs with customers.
A project dashboard helps you store, view, organize, and share files saved to the Cloud. You can share a file by copying and sending a link to its location. Everybody who receives the link will have the access privileges that you choose. You can also share a file with specific people by specifying their email addresses and access privileges.
CorelDRAW. app is integrated with CorelDRAW and Corel DESIGNER. You can save files created in CorelDRAW.app, Corel DESIGNER, or CorelDRAW to Cloud, an online storage for files, and then open these files in any of the applications. For example, you can create an illustration in CorelDRAW.app, save it Cloud, and later edit the illustration in Corel DESIGNER, taking advantage of its wide array of editing tools. After you finish editing, you can save and upload the file to Cloud directly from Corel DESIGNER. The edited file can be opened in CorelDRAW.app for annotation, but not for editing, and then saved to Cloud. If you need to edit the file, you can open it in Corel DESIGNER.
CorelDRAW.app, Corel DESIGNER, and CorelDRAW share some features, but they also differ. For information about saving, editing, and opening files with CorelDRAW.app, view a tutorial from within the app by clicking Help Learning Tutorial.
Important notes!
To open files created in CorelDRAW. app in Corel DESIGNER or CorelDRAW, and vice versa, you must save them as Corel DESIGNER (DES) or CorelDRAW (CDR) files.
The first time you access the Cloud from Corel DESIGNER or CorelDRAW, you will be prompted to sign in with the password associated with your Corel account. You need to sign in only once a year.
An Internet connection is required to open files from and save files to the Cloud.
If you need to sign in with different credentials, you must first sign out of the Cloud (Help Sign out of Cloud).
To access CorelDRAW.app
In the
Sign in to Cloud dialog box, type the email address and password associated with your Corel.com account.
If you are a corporate user of CorelDRAW Technical Suite, you can also sign in to CorelDRAW.app Enterprise with your corporate Microsoft 365 or Google Workspace account.
To open a Corel DESIGNER (DES) file saved to the Cloud
In Corel DESIGNER, click
File Open from Cloud.
On the project dashboard, double-click the file you want to open.
You can also open a Corel DESIGNER file from the Cloud by clicking the Open from Cloud button on the standard toolbar.
You can also open a file from the Cloud by clicking Open from Cloud in the Welcome screen.
To save a Corel DESIGNER (DES) file to the Cloud
File Save to Cloud.
On the project dashboard, choose the folder where you want to save the file, and type a file name.
Click
Save to save the file and upload it to the Cloud.
Save the file to the CorelDRAW (CDR) file format, or to an earlier version of Corel DESIGNER
Choose the file format and version from the File format and version box.
Break the link between a file saved to the Cloud and its locally saved version
In Corel DESIGNER, click File Save As, and save the file to the local folder you want.
A file saved to the Cloud can be identified by the cloud icon beside its name .
To find, organize, and view files saved to the Cloud
Click
File Save to Cloud or
File Open from Cloud to show the project dashboard.
Perform a task from the following table.
Start typing the file name in the Search box.
Create a new folder to organize your files
Click New folder, and specify the folder name.
View files as large thumbnails or a list
Click the Card view button or the List view button in the upper-right corner of the project dashboard.
Click the Sorting button , and click a command.
To share a file saved to the Cloud
Click
A pane showing the file thumbnail is displayed to the right.
Click
Share This File at the bottom of the file thumbnail.
4
In the
Share File dialog box, do one of the following:
Click
Copy to copy the link. From the
Everybody with the link box, choose the access privileges of all people who will receive the link:
Viewer,
Reviewer, or
Approver.
In the
Private Sharing section, type the email addresses of the people you want to share the file with, and specify the access privileges for each person.
To sign out of Cloud
Help Sign out of Cloud.
