Create bulleted and numbered lists
You can use bulleted and numbered lists to format paragraph text, and you can create lists inside lists (multilevel lists).
Three paragraphs were converted into a bulleted list (left) and a numbered list (right).
In addition, you can customize lists, and you can customize one or more levels in multilevel lists. Corel DESIGNER lets you edit bullets and numbers by changing their size, position, and distance from the text and text frame. By default, the first level in lists inherits the font properties of the paragraph text. However, you can change the font of bullets and numbers, and you can choose from a wide array of glyphs to use as bullets. To customize the number formatting, you can choose from numerous preset styles, and you can specify a suffix and a prefix for the numbers.
A customized bulleted list (left) and numbered list (right)
To reuse custom lists, you can save them as a paragraph style. You can remove the bulleted-list and numbered-list formatting at any time.
You can also change the spacing between items in a list. For more information, see To adjust interline spacing.
To create a bulleted or numbered list
Back to Top
1 Using the Text tool , drag across the paragraph text that you want to format as a bulleted or numbered list.
2 Click one of the following buttons on the property bar:
• Bulleted list
• Numbered list
You can also
Create a multilevel list
To indent a list item, click the item with the Text tool , and click the Increase indent button on the property bar.
To decrease the indentation of a list item, click the Decrease indent button.
To change the indentation of multiple list items simultaneously, drag across them with the Text tool, and click an indent button.
A multilevel numbered list
Change the color of a bullet or number in a list
Select the bullet or number with the Text tool , and click a color on the color palette.
You can also start a bulleted or numbered list from scratch by creating a paragraph text frame and clicking the Bulleted list or Numbered list button on the property bar.
To customize a bulleted or numbered list
Back to Top
1 Using the Text tool , select the bulleted or numbered list you want to customize.
2 Click Text Bullets and Numbering.
The Level box in the Bullets and Numbering dialog box shows the list level you are about to edit. The top-most level of a list is 1. To customize two or more list levels at the same time, hold down Ctrl, and click the levels in the Level box to select them.
3 Perform a task from the following table.
To
Do the following
Choose a font for the bullets or numbers
Disable the Use paragraph font check box, and choose a font from the Font list box.
Choose the glyph to be used as a bullet
Open the Glyph picker, and click a glyph.
Choose the number formatting
Choose a preset numbering style from the Style list.
To add a character before the number, type a prefix in the Prefix box. To add a character after the number, type a prefix in the Suffix box.
Examples of number styles. A prefix and a suffix were added to the numbers of the third list.
Set the bullet or number size
Specify a value in the Size box.
Note: This control is not available when the Use paragraph font check box is enabled. In this case, the bullet or number matches the font and size of the paragraph text.
Adjust the bullet or number position in relation to the text baseline
Specify a value in the Baseline shift box.
Baseline shift values in points from left to right: 0, -3, 3
Set the distance between the bullet or number and the text
Specify a value in the Glyph to list text box.
Changing the distance between the bullets and the list text
Align all lines in a list item to the first line
Enable the Align lines in a list item check box.
Left: The Align lines in a list item check box is enabled. Right: The same check box is disabled.
Set the distance between the bullets or numbers and the text frame
Specify a value in the Text frame to list box, which is located in the upper-right corner of the dialog box.
Preview the list in the drawing window
Make sure the Preview check box is enabled.
Switch the list type
Enable the Bullets or Numbers option.
Bullets or numbers are inserted at the beginning of each new line that is preceded by a return.
You can also create a custom list from paragraph text that has not been formatted as a list yet. Select the paragraph text, enable the List check box in the Bullets and Numbering dialog box, and then enable the Bullets or Numbers option. Perform any of the steps from the preceding table.
You can adjust the spacing in between bullets by increasing or decreasing the space before and after a paragraph. For more information, see To adjust the spacing between paragraphs.
To save a list as a paragraph style
Back to Top
1 Using the Text tool, drag across an item in a bulleted or numbered list to select it.
2 Right-click, and click Object Styles New Style From Paragraph.
3 In the dialog box that appears, type a style name in the New Style Name box.
To remove bulleted-list or numbered-list formatting
Back to Top
1 Using the Text tool , drag across a bulleted or numbered list to select it.
• Bulleted list
• Numbered list
