If the preset templates do not meet your needs, you can create your own templates, based on documents that you often use. For example, if you regularly put together a newsletter, you can save the page layout settings and styles to a template.
When you save a template, Corel DESIGNER allows you to add reference information, such as pagination, folds, and category. Although adding template information is optional, doing so makes it easier to organize and locate templates later on.
You can change the default location to which templates are saved. For more information, see Change content locations.
If you click Cancel, you close the Template properties dialog box without saving the template.
If you don’t want to add reference information, click Save without specifying any of the options.
