Document palette
When you start a new drawing, an empty color palette, called the Document palette, appears docked in the lower-left corner of the drawing window. Every time you use a color in your drawing, it’s automatically added to the Document palette. However, if you prefer to control which colors are added to the Document palette, you can disable the automatic updates and add colors manually.
When adding colors manually, you can choose colors from a color palette, an external image, or a color picker. In addition, you can add colors from an imported image or object.
Drag a bitmap to the Document palette to add colors.
When you open documents that were created in a previous version of Corel DESIGNER, only color styles and spot colors are added to the Document palette. However, you can add all colors from an existing drawing to the Document palette.
You can clear the Document palette of any unwanted or unused colors by removing colors individually or refreshing the palette to remove all unused colors at once.
To show or hide the Document palette
Back to Top
• Click Window Color Palettes Document palette.
Hiding the Document palette does not disable the automatic adding of colors.
To disable the automatic adding of colors to the Document palette
Back to Top
• On the Document palette, click the flyout button , and then click Palette Auto-Add Colors.
By default, the Document palette is docked above the status bar at the bottom of the application window.
You can also disable the automatic adding of color by clicking Tools Options Customization, clicking Color Palette in the left pane of the dialog box that appears, and disabling the Automatically update the document palette check box.
To manually add colors to the Document palette
Back to Top
To
Do the following
Add a color from another color palette
Drag a color from an open color palette to the Document palette.
Add a color from a bitmap image
On the Document palette, click the Eyedropper button , and click a color in the image.
Add multiple colors from an image
On the Document palette, click the Eyedropper button , hold down Ctrl, and then click the image until you add the colors that you want.
Add multiple colors from an image or object by dragging
Drag an image or object from the drawing window to the Document palette.
Add colors from a selection
Select an object or multiple objects. On the Document palette, click the flyout button , and then click Palette Add from Selection.
When dragging most vector objects to the palette, you add all object colors to the palette. When dragging a bitmap, you can specify the number of colors that you want to be added to the palette. If an object includes a fountain fill, texture fill, or pattern fill, only colors that are defined during the fill creation are supported. Colors from PostScript fills are not supported.
To add colors from an existing drawing to the Document palette
Back to Top
1 Open a drawing.
2 On the Document palette, click the flyout button , and then click Palette Add from Document.
If the drawing was created in a previous version of Corel DESIGNER and it includes custom spot colors, they appear in the Document palette.
If you have a document with both vector and bitmap images, and you want to add only the colors from the vector images to the Document palette, specify 0 in the Add colors from bitmap dialog box.
To remove colors from the Document palette
Back to Top
1 Click a color swatch on the Document palette.
2 On the Document palette, click the flyout button , and click Delete Color.
You can also remove all colors that are no longer used from the Document palette by clicking the flyout button , and clicking Palette Refresh.
