Draw cylinders and prisms
You can draw cylinders and prisms in projected view. You can adjust the length and radius of these projected shapes by specifying values or by moving their control handles in the drawing window.
With prisms, you can specify the number of sides of the base faces.
Examples of a cylinder and a prism. Control handles let you adjust the length and radius of the shapes.
To draw a cylinder or prism
Click one of the following tools:
Cylinder
Prism
Drag in the drawing window to set the radius of the shape, then move the pointer to set the length, and click.
To modify a cylinder or prism
Cylinder
Prism
Click the projected shape, and perform any of the following tasks.
Type a value in the top portion of the Radius and length box on the property bar.
Type a value in the bottom portion of the Radius and length box on the property bar.
Specify the number of sides of the base faces of a prism
Type a value in the Sides box.
The radius, length, and distance values are applied in projected space.
To adjust a cylinder or prism by using control handles
Using the
Cylinder
or
Prism
tool, click the shape to display the control handles.
Point to a control handle, and when the cursor changes to an arrow, perform any of the following tasks:
Drag the radius control handle.
Tip: You can also drag the handle to rotate the prism.
Drag the length control handle.
