Edit perspective groups
You can edit perspective groups by moving and editing the objects in the group, and by adding objects.
You can move, rotate, and scale objects within a perspective group. Also, you can move an object in a perspective group from one plane to another to change its view. For example, you can place the object on the orthographic plane to remove the perspective, or you can move an object from the top plane to a side plane, and vice versa. You can also move objects from the orthographic plane to any available perspective plane.
The objects are moved from the orthogonal plane (left) to the left plane (right).
While you are in Edit mode, you can add existing objects, such as vector shapes, text and bitmaps, to the perspective group by moving them to a plane. Text added to perspective groups isn’t converted to curves, so you can edit and reformat it.
You can also shape and edit the objects in a perspective group by using the Shape tool. When you draw and edit objects in a perspective group, snapping to perspective lines (View
Snap To
Perspective Lines) is enabled by default. If you want to snap objects only to guidelines, you can disable snapping to perspective lines. For more information about using guidelines to help with object placement, see Set up guidelines.
You can move and scale proportionally perspective groups as you would any other groups. However, perspective groups can’t be resized nonproportionally, rotated, or skewed.
In addition, you can modify the appearance of the perspective field in each perspective group. For example, you can hide and show horizon and perspective lines, and you can customize the color of the lines and adjust their opacity. Adjusting the line color and opacity can help you focus on the objects you draw; conversely, it can make the lines and handles stand out so that you can adjust the perspective field more easily.
Depending on the drawing precision you want, you can adjust the density of the perspective field by adding or removing perspective lines.
The perspective field is customized by changing the color of the horizon line and viewport, and increasing the number and opacity of the perspective lines.
To edit a perspective group
Select a perspective group.
Click
Edit in the upper-left corner of the drawing window.
A floating toolbar appears.
Select an object in the perspective group
Click the object using the Pick tool  .
Tip: You can also marquee-select the object.
Move an object along the plane it was drawn
Using the Pick tool, drag the object to a new position. The object maintains its perspective but is redrawn to reflect its new position in relation to the vanishing point.
• You can also use the arrow keys to nudge the object.
• You can specify x and y coordinates on the property bar.
Tip: To resize the object non-proportionally, drag a middle handle.
Click the object to display the rotation handles, and drag a rotation handle.
Move an object to another plane
Right-click the object, click Move to Plane, and then click one of the following commands:
• Move to Orthogonal Plane — to place the object on a flat plane, removing the perspective
• Move to Top Plane — to place the object on the top perspective plane
• Move to Left Plane — to place the object on the left perspective plane
• Move to Right Plane — to place the object on the right perspective plane
• Move to Side Plane — to place the object on the side perspective plane
Note: Only commands relevant for the selected object are displayed.
Add an object to the perspective group
Right-click the object, click Move to Plane, and click a command.
Click
Finish on the floating toolbar.
Perspective groups cannot be edited when Focus mode is activated. For more information about Focus mode, see Edit objects in Focus mode.
You can start editing a selected perspective group by clicking Object
Perspective
Edit Perspective Group.
You can also right-click a perspective group, and click Edit Perspective Group.
To reshape an object placed on a perspective plane
Click
Using the
Shape tool
, click the object you want to edit.
The object is temporarily moved to the orthographic plane.
4
Edit the object to achieve the shape you want.
5
Click the
Pick tool
The edited object is automatically projected on the perspective plane where it resided before it was edited.
Some objects are drawn on a perspective plane (upper-left). When clicked with the Shape tool, the first object is temporarily placed on the orthographic plane (upper-right). The Shape tool is used to edit the shape (lower-left). When the Pick tool is selected, the edited object is automatically placed back on the perspective plane (lower-right).
To edit text placed on a perspective plane
Click
To move or scale a perspective group
Using the
Pick tool
, select a perspective group.
Do any of the following:
Drag the group to a new position in the drawing window.
Drag a handle to scale the group.
Perspective groups can’t be resized nonproportionally, rotated, or skewed. To apply any of these transformations to a perspective group, you must break it apart first. For more information, see Break perspective groups apart.
To modify the appearance of the perspective field
Click
Using the controls on the toolbar that appears, perform a task from the following table.
Show or hide the camera lines
Click the Show camera lines  button.
Show or hide the horizon lines
Click the Show horizon button  .
Change the opacity of horizon lines
Move the Horizon opacity slider.
Change the color of horizon lines
Choose a color from the Horizon color picker.
Show or hide perspective lines
Click the Show perspective lines button  .
Adjust the density of the perspective field
Move the Density slider to add or remove perspective lines.
Change the opacity of perspective lines
Move the Line opacity slider.
Change the color of perspective lines
Choose a color from the Line color picker.
4
Click
