Edit styles and style sets
You can edit a style or style set either by changing its attributes in the Object Styles docker, or by changing the attributes of an object linked to the style or style set, and then applying these changes to the style or style set.
You can also edit a style or style set by copying attributes from an object to the style or style set.
You can override style attributes. When you override an attribute, it is no longer related to the style definition, and changes to the style do not affect the object until you remove the override.
To edit a style
Back to Top
1 Click Window Object Styles.
2 In the Object Styles docker, open the Styles folder, and select a style.
3 In the style properties area of the Object Styles docker, modify the attributes you want.
To edit a style set
Back to Top
2 In the Object Styles docker, open the Style Sets folder, and select a style set.
3 Click the Add or remove style button next to the style set, and click the style type that you want to add or remove from the style set.
Check marks appear next to the style types that are included in the style set.
In the style properties area of the Object Styles docker, you can edit the styles that are included in the style set.
To edit a style or style set by editing an object
Back to Top
1 Using the Pick tool , select an object that has a style or style set applied to it.
2 Click Edit Properties.
3 In the Properties docker, edit the object properties.
4 In the document window, right-click the object, choose Object Styles from the context menu, and choose Apply to Style.
The new attributes of the object replace the attributes of the styles or style sets associated with this object.
To edit a style or style set by copying properties from an object
Back to Top
2 Drag an object from the document window over a style or style set name in the Object Styles docker.
You can also copy the properties of an object to a style or style set by right-clicking the style or style set in the Object Styles docker, choosing Copy Properties From, and then clicking an object in the document window.
To override a style attribute
Back to Top
1 Using the Pick tool , select an object that has a style applied to it.
3 In the Properties docker, edit an object attribute defined by a style.
The source indicator next to the attribute changes from green with a vertical line to orange with a horizontal line , showing that the object attribute is no longer defined by the style.
To remove a style override, do one of the following:
• Click the orange source indicator , and choose Revert.
• In the document window, right-click the object by using the Pick tool , choose Object Styles from the context menu, and choose Revert to Style.
