Embed graphics
You can embed a graphic object or bitmap in text. The graphic object or bitmap is treated as a text character. As a result, you can apply formatting options according to the type of text in which you embed the graphic object. You can also remove an embedded object from text, after which the object returns to its original state.
To embed a graphic object in text
Click
Edit, and click one of the following:
Using the
Text tool
, click where you want to embed the graphic object.
4
Click
Edit
Paste.
To remove an embedded object from text
Using the
Text tool
, select an embedded
object.
Click
Edit
Cut.
Click the
Pick tool
, and click outside the text object.
4
Click
Edit
Paste.
