Find templates
Corel DESIGNER provides an easy way of finding templates.
You can search by the file name, title, or keywords associated with a template. For example, if you type "certificate" in the text field, the application automatically filters out all files that do not match, and you see only the files that have the word "certificate" in the file name or keywords. You can cancel a search at any time.
You can narrow the search results by using the template source (for example, only templates created by you) and category (for example, Brochures, Flyers, or Letterheads & Letters). You can also view the list of your favorite or most recently used templates and sort templates by the name and the date they were created or modified.
You can browse and search either the entire local library (local templates included with Corel DESIGNER and provided by third-party designers, as well as templates that you have created) or online library (online templates provided by Corel DESIGNER) or one pack, folder or list at a time within those libraries.
Add templates
To get you started, Corel provides templates from the Corel online library and local templates (stored in your Documents\Corel\Corel Content\Templates folder) that appear by default on the Templates tab of the Create a New Document dialog box. If you are looking to expand your template collection, you can download additional template packs from within the Get More dialog box.
To access templates that are saved to local folders outside your Documents\Corel\Corel Content\Templates folder, you can create links (also known as aliases) to these folders. In addition, aliases can be used to access templates saved to shared network locations as well as secondary storage devices such as USB flash drives, and portable hard drives.
When you copy a folder that contains many templates to your computer, it may take some time for your operating system to index the folder. To view, browse, and search templates in such a folder right away, you may need to reindex the folder.
View template and template information
You can increase the size of thumbnails to recognize a particular template easier and faster, and you can decrease thumbnail size to view more search results at a glance.When you select a template in the viewing area, additional information is displayed about the template’s category, style, pagination, and fold options.
To find, filter, and sort templates
Back to Top
1 Click File New from Template.
2 Click the Options button Choose content source, and choose an option.
If you want to search or browse all templates provided by Corel and any templates added by you, choose All folders.
3 Perform a task from the following table.
You can also
Find templates
Type a word in the Search box, and press Enter.
Templates that match the search term appear in the preview window.
Tip: To clear the search, delete the search term. Optionally, press Enter to see the default list of templates.
Filter templates
From the Filter templates based on categories list box, choose a category.
Sort templates
From the Sort templates by name or date list box, choose one of the following options:
• Favorites — shows your favorite templates. Templates in your Favorites list are sorted by name. For information about marking templates as favorite, see To tag, rename, and delete templates.
• Recent — shows the most recently used templates. Templates in your Recent list are sorted by name.
• Name — sorts templates by file name, in alphanumeric order
• Date Created — sorts templates by the date they were created, starting with the last created template
• Date Modified — sorts templates by the date they were modified, starting with the last modified template
Browse or search all items in your library
From the Filter templates based on categories list box, choose All categories. Click the Options button , and click Browse recursively.
Reindex a folder
Click the Options button , and click Reindex folder.
When you choose My templates as the content source, you can browse all templates located in the root of your Documents\Corel\Corel Content\Templates folder.
If the Corel DESIGNER shell integration components are not installed (that is, if you have disabled the Windows Shell Extension option under Utilities in the Setup wizard during a custom installation), you can search for templates only by filename, not by name or keywords.
To download and add a new template pack
Back to Top
2 Click the Get More button.
3 In the Get More dialog box, click the template pack you want.
4 Do one of the following:
• Click Buy Now, and follow the onscreen instructions to purchase the item.
• Click Download if the item is included in your product or subscription.
To add an alias to a location that contains templates
Back to Top
2 Click the Options button Choose content source Add new.
3 Click Create alias.
4 In the Locate template library dialog box, browse to the folder or location you want.
5 Click Select Folder.
To view templates and template information
Back to Top
2 Perform one or more tasks from the following table.
To
Do the following
Increase or decrease the size of thumbnails
Move the Thumbnail size slider.
View template details
Click a thumbnail in the left pane. The template details are displayed in the right pane.
To hide the right pane where template details are displayed, disable the Show template details check box.
