Fountain transparency
Fountain transparency makes the object fade from one transparency value to another. The fountain transparency can be linear, elliptical, conical, or rectangular.
From left to right: Original object with a linear, elliptical, conical, and rectangular transparency applied.
The application provides a collection of fountain transparencies that you can access. You can browse the available transparencies, search by keyword, mark transparencies as favorites, and sort them. You can also download additional fill packs, which can be used as transparencies. For more information, see Find and view fills and transparencies.
You can create a fountain transparency by adding and removing nodes, and specifying a transparency value for each node. You can also reverse, mirror, resize, or skew a fountain transparency, or apply other transformations.
After you create a fountain transparency, you can save it for future use or share. For more information, see Save fills and transparencies.
To apply a fountain transparency
Back to Top
1 Select an object.
2 Click Edit Properties.
3 In the Transparency area of the Properties docker, click the Fountain transparency button to display fountain transparency options.
4 Open the Transparency picker, and double-click a thumbnail.
You can also
Apply the transparency only to the fill or the outline of the object
Click the Fill button or the Outline button in the Transparency area of the Properties docker.
Modify the transparency
Click the Edit transparency button in the Properties docker, and specify the settings you want.
You can also click the Transparency tool in the toolbox, and use the controls on the property bar to apply a fountain transparency.
For information about how to find transparencies in the Transparency picker, see To find, filter, and sort fills and transparencies.
To create a fountain transparency
Back to Top
1 Select an object.
4 Click one of the following buttons to choose a fountain transparency type:
• Linear fountain transparency
• Elliptical fountain transparency
• Conical fountain transparency
• Rectangular fountain transparency
5 Click the first node below the grayscale band, and type a value in the Opacity box.
6 Click the last node below the grayscale band, and type a value in the Opacity box.
7 Move the midpoint slider above the grayscale band to set the midpoint of the transparency.
To save the transparency, click the click the Save as new button in the Transparency area of the Properties docker.
You can also
Change the transparency of the midpoint
Select the midpoint node, and type a value in the Opacity box.
Add an intermediate transparency
Double-click the grayscale band where you want to add a node. With the new node selected, type a value in the Opacity box.
Change the position of an intermediate transparency
Drag the corresponding node to a new location below the grayscale band, or type a value in the Position box.
Delete an intermediate transparency
Click the Transparency tool , and double-click the node on the interactive vector handles that appear on the object.
Allow the transparency to be skewed or stretched disproportionately
Enable the Free scale and skew check box.
Mirror, repeat, or reverse the transparency
Click the Edit transparency button , and click one of the following buttons:
• Repeat and mirror
• Repeat
• Reverse transparency
Specify the number of steps used to display or print the fountain transparency
Click the Edit transparency button , enable the Steps check box, and then type a value in the Steps box.
Specify how quickly the fountain transparency blends from one level of opacity to another
Click the Edit transparency button , and move the Acceleration slider.
Create smoother color transitions between fountain fill nodes
Click the Edit transparency button , and enable the Smooth transition check box.
Set the width and height of the transparency as a percentage of the object’s width and height
Click the Edit transparency button , and type values in the Transparency width and Transparency height boxes.
Move the transparency center up, down, left, or right
Click the Edit transparency button , and type values in the X and Y boxes.
Slant the transparency at a specified angle
Click the Edit transparency button , and type a value in the Skew box.
Rotate the transparency at a specified angle
Click the Edit transparency button , and type a value in the Rotate box.
To apply the transparency only to the fill or the outline of the object, click the Fill button or the Outline button .
You can also click the Transparency tool in the toolbox. To adjust the transparency, use the controls on the property bar or the interactive vector handles that appear on the object.
You can also drag colors, which are converted to grayscale, from the color palette onto the transparency nodes. Alternatively, if the Transparency tool is selected, you can drag the colors onto the object’s interactive vector handles .
