Import 3D models
Corel DESIGNER lets you import 3D models as 2D vector graphics to your illustrations. Before importing a graphic into Corel DESIGNER, you must open it with XVL Studio Corel Edition. After you open the 3D model, you can preview it from different angles. For example, you can specify parallel or perspective projected views. You can also change the position, orientation, and size of a 3D model, and you can create cross-sections. When you are satisfied with the view of the 3D model in XVL Studio Corel Edition, you can import it as a 2D vector graphic into the active drawing or save it for later use.
XVL Studio Corel Edition lets you import files saved to the following 3D file formats:
• AutoCAD (DWG and DXF) — 3D polygon data only. Volume geometries are not supported.
• 3D Studio (3DS)
• VRML
• Universal 3D (U3D)
• IGES
If you want to use additional file formats, you can upgrade to XVL Studio 3D CAD Corel Edition, which supports native 3D CAD file formats including CATIA, SolidWorks, Autodesk Inventor, NX, PTC Creo, and more. It also supports 3D CAD exchange formats such as JT, STEP, and Parasolid.
For a detailed list of the 3D CAD file formats supported by XVL Studio 3D CAD Corel Edition, see the Help system within XVL Studio 3D CAD Corel Edition.
To import a 3D model
Back to Top
1 Click File 3D Import.
If this menu command is not available, you must install XVL Studio Corel Edition.
2 In XVL Studio Corel Edition, open and adjust the 3D model that you want to import.
3 Click File Send to Corel DESIGNER.
If you want to adjust the size and position of the 2D graphic, specify the settings you want in the Send to Corel DESIGNER dialog box.
4 Click Send.
You can also
Access Help
In XVL Studio Corel Edition, click Help Help.
Export a 3D model
In the Send to Corel DESIGNER dialog box, click Export.
Preview a 3D model
In the Send to Corel DESIGNER dialog box, click Preview.
Open a 2D view of a 3D model in CorelDRAW
In XVL Studio Corel Edition, click File Send to CorelDRAW.
Open a 2D view of a 3D model in Corel PHOTO-PAINT
In XVL Studio Corel Edition, click File Send to Corel PHOTO-PAINT.
If you have the advanced-level XVL Studio 3D CAD Corel Edition add-on installed, you can access settings for line types or fonts for creating illustrations in the Send to Corel DESIGNER dialog box by clicking Details.
You can publish to 3D PDF from Corel DESIGNER, creating documents that combine text, vector graphics, images, and embedded 3D models. Using a PDF reader that supports 3D PDF viewing, such as Adobe Reader, the end user can interact with the 3D model, so they can rotate, move, and size it.
