Installation options
You can choose between the following types of installations:
Typical installation — automatically installs the main programs and utilities of the suite to a default location in the Program Files folder. If later you need a component that is not installed, you can modify your installation.
Custom installation — lets you choose additional features, exclude components that you don’t need, and specify where to install the suite. If you have purchased a multilingual version of the suite, you can also choose which language packs to install.
Deployment — available only for multiseat purchases. This option lets you create a server image for installing the software to individual workstations. For more information, see the CorelDRAW Technical Suite Deployment Guide.
Programs
The following table lists the programs that are installed by default. To exclude a program from the installation, you must choose Custom installation.
Program
Description
Corel DESIGNER
A full-featured vector graphics application with dedicated technical illustration tools and industry-standard output support
CorelDRAW
An intuitive and versatile graphics application for creating high-quality vector illustrations, logo designs, and page layouts
Corel PHOTO-PAINT
A complete image-editing application that lets you retouch and enhance photos as well as create original bitmap illustrations and paintings
CAPTURE
An easy-to-use application for capturing images from your computer screen
Corel Font Manager
An application for finding, organizing, and managing fonts
Corel BARCODE WIZARD
An application for generating bar codes in a wide range of industry-standard formats
XVL Studio Corel Edition
A 3D-authoring application for creating high-quality illustrations and renderings from DWG, 3DS and other 3D file formats
XVL Player
An application for viewing 3D files
Program features and utilities
The following table lists the program features that you can install. Not all components are available in all versions of the software.
Feature or utility
Description
Notes
Microsoft Visual Basic for Applications 7.1
A subset of the Microsoft Visual Basic (VB) programming environment, which is suitable for beginners.
You can use VBA to create basic macros for personal use, but you can also use it to create more advanced macro projects.
Microsoft Visual Studio Tools for Applications (VSTA)
A built-in program environment that allows developers and other programming experts to use VSTA for creating the most advanced macro projects
To use VSTA with CorelDRAW Technical Suite, you must have your own copy of Microsoft Visual Studio 2019 installed.
If you install Microsoft Visual Studio after installing CorelDRAW Technical Suite, you must re-install the VSTA feature by modifying your CorelDRAW Technical Suite installation. For more information, see To modify or repair a CorelDRAW Technical Suite installation.
Windows Shell Extension
Lets you view thumbnails of native Corel files such as CorelDRAW (CDR), Corel PHOTO-PAINT (CPT), pattern fill (FILL), and other native file.
If you have installed CorelDRAW Graphics Suite or CorelDRAW Technical Suite before, this option does not appear in the installation wizard.
GPL Ghostscript
Highly recommended if you import EPS and PDF files in your documents. This feature lets you isolate and use individual elements of imported EPS files rather than only header images. It also improves the import of PDF files generated by third-party applications.
Included with the Typical installation
Product languages
Let you use the programs and Help in two or more languages
This option is included only with multilingual versions of the software and requires Custom installation.
Install desktop shortcuts
Adds product icons to your desktop for easy access
Copy installation files
Lets you maintain and update the software without using the installation disc
