JPEG (JPG)
JPEG is a standard format developed by the Joint Photographic Experts Group. Through the use of superior compression techniques, this format allows the transfer of files among a wide variety of platforms. JPEG supports 8-bit grayscale, 24-bit RGB, and 32-bit CMYK color modes.
The JPEG format is commonly used on the web. For more information about exporting to the JPEG file format, see Export bitmaps for the web.
To import a JPEG file
Back to Top
1 Click File Import.
2 Locate the folder in which the file is stored.
3 Choose JPG - JPEG Bitmaps (*.jpg; *.jtf; *.jff; *.jpeg) from the list box next to the File name box.
4 Click the filename.
5 Click Import.
6 Click the drawing page.
You can also
Resample a graphic while importing
For more information, see To resample a bitmap while importing.
Crop a graphic while importing
For more information, see To crop a bitmap while importing.
You can drag on the drawing page to resize the image.
JPEG technical notes
Back to Top
• JPEG files can contain EXIF data. This data may affect how the JPEG files open.
