Mirror objects
With Corel DESIGNER, you can create mirror images of objects. Mirroring an object flips it from left to right or top to bottom. By default, the anchor point is in the center of the object.
To mirror an object
Click
Object
Transform
Scale and mirror.
In the
Transform docker, enable the
Mirror horizontally option
or the
Mirror vertically option
4
In the
Transform docker, click the point on the origin locator
that corresponds to the point on the object about which you want to mirror the object.
To leave the original object unchanged and apply the transformation to a copy, type
1 in the
Copies box in the
Transform docker.
You can also mirror a selected object by holding down Ctrl and dragging a selection handle to the opposite side of the object.
