OpenType features
Corel DESIGNER supports OpenType fonts so you can take advantage of their advanced typographic features. OpenType features allow you to choose an alternate appearance for an individual character (also referred to as a glyph) or a sequence of characters. For example, you can choose alternate glyphs for numbers, fractions, or ligature sets.
You can access OpenType commands and options in the Character area of the Properties docker. You can also let Corel DESIGNER prompt you which OpenType features you can apply by enabling the Interactive OpenType option. When you select text, an indicator arrow appears below the text if an OpenType feature is available. You can click the indicator to access a list of the most popular available OpenType features.
Clicking the Interactive OpenType indicator arrow (1) expands a list of the most popular OpenType features that are available for the selected text.
The OpenType font specification was created jointly by Adobe and Microsoft. Based on Unicode, OpenType fonts extend the capabilities of older font technologies. The most notable advantages of OpenType are:
cross-platform support (Windows and macOS)
extended character sets that offer better language support and advanced typographic features
coexistence with Type 1 (PostScript) and TrueType fonts
support for a larger glyph limit (64k)
OpenType features
The following table describes the OpenType features that you can apply in Corel DESIGNER provided that the feature is included in the font.
In addition, Corel DESIGNER also provides synthesized versions of some Caps and Position OpenType features. For example, if a font does not support a feature, such as Small Caps, Corel DESIGNER produces its own version of the glyph by scaling the font.
Changes the case of text, which is useful for inserting titles and acronyms
Small caps
Displays characters as superscript or subscript, which is useful for inserting footnotes or mathematical symbols. If you select an OpenType font that does not support subscript and superscript, or a non-OpenType font, you can apply a synthesized glyph.
Superscript
Includes features for controlling the appearance of numbers
See examples below
Number styles — Proportional lining
Displays numbers of varying width, which is best suited for inserting numbers in body text. However, the numbers have a fixed height, which generally matches the height of capital letters.
![](../Shared_graphics/Corel-DESIGNER-OpenType-number-proport.png)
Number styles — Tabular lining
Displays numbers of equal width, spacing, and height, which is useful for aligning text and displaying text in a table
![](../Shared_graphics/Corel-DESIGNER-OpenType-number-tabular.png)
Number styles — Proportional Oldstyle
Displays numbers of varying width and height. The style is best suited for blending numbers with mixed text case.
![](../Shared_graphics/Corel-DESIGNER-OpenType-number-proport-old.png)
Number styles — Tabular Oldstyle
Displays numbers of equal width, but varying height
![](../Shared_graphics/Corel-DESIGNER-OpenType-number-tabular-old.png)
Displays numbers separated by a slash as fractions. The number of available fractions vary from font to font. Apply this feature only to the numbers that you want to display as a fraction.
See examples below
Displays a numerator, such as 456/, as a fraction glyph. This is useful for displaying a non-standard fraction, such as 456/789, as a fraction. Use the Numerator feature in conjunction with the Denominator feature to display non-standard fractions as fractions.
![](../Shared_graphics/Corel-DESIGNER-OpenType-fraction-num.png)
Displays a denominator, such as /789, as a fraction glyph. This is useful for displaying a non-standard fraction, such as 456/789, as a fraction. Use the Denominator feature in conjunction with the Numerator feature to display non-standard fractions as fractions.
![](../Shared_graphics/Corel-DESIGNER-OpenType-fraction-denom.png)
Displays standard fractions as fraction glyphs
![](../Shared_graphics/Corel-DESIGNER-OpenType-fraction.png)
Fraction — Alternative fraction
Displays a fraction by using a horizontal dividing line instead of a slant or slash
Not available
Displays ordinals by using a number and a suffix in superscript. For example, you can display "first" as 1st or "second" as 2nd. Apply this feature only to the text that you want to display as an ordinal.
![](../Shared_graphics/Corel-DESIGNER-OpenType-ordinals.png)
Displays zeros with a diagonal slash, which makes them easy to distinguish from the letter O. This feature is useful for displaying numbers in financial reports.
![](../Shared_graphics/OpenType_slashed_zero.png)
Substitutes a character with an ornament that was created by the font designer to match the font’s motif
Not available
Applies an alternate design to characters
![](../Shared_graphics/Corel-DESIGNER-OpenType-stylistic-alternatives.png)
Applies an alternate design to a text selection
![](../Shared_graphics/Corel-DESIGNER-OpenType-stylistic-sets.png)
Inserts calligraphic-type decorative characters
![](../Shared_graphics/Corel-DESIGNER-OpenType-swash-variants.png)
Lets you fine-tune text by applying an alternate design to a single character, or a sequence of characters, based on its surrounding characters. For example, you can apply this feature to script-based text so that it flows more naturally.
Not available
Shifts the position of punctuation marks so they align with capitalized text or lining numbers
Not available
Replaces a letter pair (or a sequence of letters) with one glyph, which is called a ligature. Many OpenType fonts include standard ligatures for fi, fl, ff, ffi, and ffl. Their purpose is to improve text readability.
![](../Shared_graphics/Corel-DESIGNER-OpenType-standard-ligatures.png)
Replaces a non-standard letter combination with a ligature. Discretionary ligatures designed to be decorative and are not supported by the majority of OpenType fonts.
![](../Shared_graphics/Corel-DESIGNER-OpenType-discretionary-ligatures.png)
Inserts a glyph that best suits the surrounding characters. Contextual ligatures are designed to increase readability by improving the joining behavior between the characters of a ligature.
Not available
Substitutes a letter pair, or a letter sequence, with a ligature that is based on historical usages. Historical ligatures are designed to be ornamental and are not supported by the majority of OpenType fonts. The most commonly-used historical ligatures are the letter s combined with another character, such as sh si sl ss, and st.
Not available
Substitutes modern characters with characters that were commonly used in historical documents. Historical forms are useful for recreating historical text.
Not available
To apply an OpenType feature to text
Using the
Text tool
![](images/loc-text-tool.svg)
, a single character or a sequence of characters.
If the
Properties docker is not open, click
Window
Properties.
In the
Properties docker, click the
Character button
to display the character-related options.
In the
Properties docker, click an OpenType feature button, and, if applicable, choose a feature from the list.
![*](images/note.svg)
Some OpenType fonts may appear to support features that are not supported.
To enable the onscreen OpenType feature indicator
Click the
Text tool
, and then click the
Interactive OpenType button
![](../Shared_graphics/opentype-interactive.svg)
on the property bar.
If an OpenType feature is available for the selected text, an arrow
![](../Shared_graphics/down-arrow.svg)
appears below the text.
View a list of the most popular OpenType features onscreen
Click the down arrow ![](../Shared_graphics/down-arrow.svg) below the text in the document window.
Apply an OpenType feature to a text selection
In the OpenType feature list, click a feature.
