PDF preflight summaries
Before saving a document as a PDF file, you can preflight your document to find potential problems. Preflighting checks and displays a summary of errors, possible problems, and suggestions for resolving issues. By default, many PDF issues are checked during a preflight, but you can disable the issues that you do not want to check.
To view the preflight summary for a PDF file
Click
File
Publish to PDF.
Locate the folder in which you want to save the file.
Type a filename in the
File name box.
The
PDF settings dialog box appears.
5
Click the
Preflight tab.
If there are no print job issues, the tab name displays as
No issues. If there are issues, the tab name displays the number of issues that were found.
You can limit the issues to check during the preflight by clicking the
Preflight tab, clicking the
Settings button
, and, in the
Preflight settings dialog box, disabling the check boxes next to the items that you want the preflight to overlook.
You can save settings by clicking the Add preflight settings button
and typing a name in the Save preflight style as box.
