Polygons and stars
Corel DESIGNER lets you draw polygons and two types of stars: perfect and complex. You can draw polygons and stars and then reshape them. For example, you can convert a polygon to a star by dragging its nodes, and you can change the number of sides on a polygon.
Perfect stars are traditional-looking stars and can have a fill applied to the entire star shape. Complex stars have intersecting sides and produce original results with a fill applied.
You can also draw a predefined star shape. For more information, see To draw a predefined shape.
To draw a polygon
Click the
Center-point polygon tool
Point to where you want the center, and drag in the drawing window until the polygon is the size you want.
Example of using a polygon to create a nut
You can change a polygon to a star by selecting the polygon with the Shape tool, clicking a node on one of the sides, and dragging toward the center of the polygon.
To draw a star
In the toolbox, click the
Star tool
Perform a task from the following table.
On the property bar, click the Star button  , and drag in the drawing window until the star is the size you want.
On the property bar, click the Complex star button  , and drag in the drawing window until the star is the size you want.
To reshape a polygon
Click the Shape tool  , and click a node on the polygon. Drag the node to change the polygon’s shape.
Change the number of sides of a polygon
Select a polygon. Type a value in the Points or sides box on the property bar, and press Enter.
To modify a star
Change the number of points on a star
Select a star, type a value in the Points or sides box on the property bar, and press Enter.
Select a star, click the Shape tool  , and drag a node on the star.
When you use the Shape tool to reshape a perfect star, the node movement is constrained. Also, you cannot add or delete nodes, or convert line segments to curves.
