Print styles
A print style is a set of saved printing options. Each print style is a separate file. This lets you move a print style from one computer to another, back up a print style, and keep document-specific styles in the same directory as the document file.
You can select an existing print style, create a new print style, or edit a print style and save the changes. You can also delete print styles.
To choose a print style
Back to Top
1 Click File Print.
2 Click the General tab.
3 Choose one of the following from the Print style list box:
• Corel DESIGNER defaults
• Browse
To create a print style
Back to Top
1 Click File Print.
3 Set any printing options.
4 Click Save as.
5 Choose the folder where you want to save the print style.
6 Type a name for the style in the File name box.
When you save a print style, a dialog box opens that includes a section called Settings to include. The settings in this section correspond to the printing options you have already selected. You can also specify which settings to include in a print style in this dialog box.
You can also save a print style by clicking File Print preview, and clicking the Save print style as button.
To edit a print style
Back to Top
1 Click File Print Preview.
2 Choose a print style from the Print style list box.
3 Modify any of the printing options.
4 Click Save as.
5 Choose the folder where the print style is stored.
6 Click the filename.
7 Click Save.
You should save the modified settings as a print style or apply the changes before canceling; otherwise, you’ll lose all the modified settings.
To delete a print style
Back to Top
2 Select a print style.
3 Click the Delete print style button .
