Select and move nodes
You can select individual, multiple, or all of the object’s nodes. Selecting multiple nodes lets you shape different parts of an object simultaneously. You can marquee select nodes by enclosing them with a rectangular marquee box, or by enclosing them with an irregularly shaped marquee box. Freehand marquee selection is useful when you want to select specific nodes in complex curves.
When a node is selected on curved segments, control handles are displayed. You can adjust the shape of the curved segments by moving the nodes and control handles.
Usually, a control handle is displayed as a solid blue arrowhead (left). When a control handle overlaps with a node, it is displayed as an unfilled blue arrowhead beside the node (right).
You can reposition a node by specifying its coordinates.
The Shape tool is the standard tool for moving nodes. You can also set an option to use the Pick and Bézier tools for selecting and moving nodes.
To select a node
In the toolbox, click the
Shape
tool.
Marquee select multiple nodes
On the property bar, choose Rectangular from the Selection mode list box, and drag around the nodes that you want to select.
Freehand marquee select multiple nodes
On the property bar, choose Freehand from the Selection mode list box, and drag around the nodes you want to select.
Hold down Ctrl, and click each node.
Select all nodes on a selected curved object
Click Edit Select all Nodes.
Holding down Shift, click the first node, and then the last node that you want to select.
To change the direction in which the nodes are selected, click while holding down Shift.
Select the node that follows or precedes a selected node
Press Tab or Shift + Tab.
Hold down Ctrl, and click a selected node.
Hold down Ctrl, and click each selected node.
Click an unused space in the drawing window.
To move a node
Select an object by using the
Shape tool
Drag the node until you achieve the desired shape.
To specify a node’s coordinate values
Click the
Shape tool
Click
Window
Coordinates.
4
Click the
Multi-point curve button
5
Type values in the
X and
Y boxes to specify the exact position of the point along the x and y rulers.
6
Click one of the following:
Create object — adds a new curve object to the drawing window
Replace object — replaces the selected curve object with a new one
