Use symbols in drawings
You can find symbols by searching or by browsing the list of available symbols. After finding the symbol you need, you can insert it into the drawing, which creates a symbol instance. You can modify certain properties of a symbol instance, such as size and position, without affecting the symbol definition stored in the library. You can also have the symbol instance scaled automatically to match the current drawing scale. For a list of object properties that you can modify in a symbol instance, see Modify symbol instances. You can convert a symbol instance back to an object while preserving its properties.
Symbols can be linked or local. A linked symbol has the symbol definition added from a library file; a local symbol (also known as "internal") was created in the active document or was made local by breaking a link.When a symbol linked from a library is changed, you can update the link to refresh all instances of the symbol.
You can also delete a symbol instance.
Symbols docker. The preview area at the top shows the name of the selected symbol, the number of instances in the document as well as the symbol type (linked or local). The tree view below the preview area lets you see all linked and local symbols in the active document and navigate to symbol libraries.
To find a symbol
Back to Top
• In the Symbols docker (Object Symbol Symbols), do any of the following:
• Click the active document at the top of the tree view to see symbols in the current document.
• Browse the Local Symbols and Network Symbols folders.
• Browse the Installed Symbols folder, which contains all symbol libraries that are included with the application.
• Click the active document or the folder you want to search, and type a keyword in the Search box. You can search by symbol name or description.
To clear the Search box, delete the words you typed.
To insert a symbol instance
Back to Top
1 In the Symbols docker (Object Symbol Symbols), choose a symbol library in the tree view.
2 Choose a symbol from the Symbols list.
If you want the symbol scaled automatically to match the current drawing scale, click the Options button , and ensure that Scale to world units is enabled.
3 Right-click the symbol, and click Insert Symbol.
You can also insert a symbol instance by dragging a symbol from the Symbols docker to the drawing window.
To modify a symbol instance
Back to Top
1 Select a symbol instance in the drawing window.
2 Make any changes.
If a symbol contains multiple objects, all objects in the symbol instance are treated as if they were a group. You cannot modify individual objects in a symbol instance.
Not all properties of a symbol instance can be modified. For a list of properties that can be modified, see Modify symbol instances.
To update links to symbols
Back to Top
1 Select a symbol in the active document.
2 Click Object Symbol Update from Link.
All symbol instances of the linked symbol are updated.
The Update from Link command appears disabled if the linked symbol has not been modified.
You can also click Window Sources and use the Sources docker to update links to symbols. An exclamation mark appears next to objects that need to be updated.
To revert a symbol instance to an object or objects
Back to Top
1 Select a symbol instance.
2 Click Object Symbol Revert to Objects.
If the external definition of the symbol instance contains styles, those styles are added to the document. If the styles in the symbol instance differ from those in its external definition, you are prompted to rename the style or merge the two styles. You can check for conflicting styles in the Links and bookmarks docker. An exclamation mark appears next to objects that need to be updated.
You can also revert a symbol instance to an object by right-clicking the symbol instance and clicking Revert to Objects.
To delete a symbol instance
Back to Top
2 Press Delete.
The symbol definition remains in the active document.
