Work with translated text
Corel DESIGNER simplifies the creation of technical documentation for a global market and reduces localization costs by offering the ability to send text to, and receive text from, a Translation Memory System (TMS). You can export text from a drawing to the XML Localization Interchange file format (XLIFF), the industry-standard format for sharing translatable text between a TMS and software. Then, when you receive the translated text back, it can be imported into the existing document, creating a new, language-specific file with identical content except the translated text strings.
By default, all paragraph text, artistic text, table text, text on a curve, and callouts in a drawing are exported for translation. You can exclude a text object from translation. When exporting text for translation, the font, font size, type face, bolding, italics, and underlining are maintained.
Corel DESIGNER simplifies the creation of technical documentation for a global market.
To export text for translation
Back to Top
1 Click File Export for translation.
2 Type a filename in the File name box.
3 Locate the folder where you want to save the file.
4 Choose one of the following options from the Save as type list box:
• XLIFF version 1.2
• XLIFF version 2.0
5 Click Save.
Text in hidden or locked text objects, or in text objects on hidden or locked layers, is excluded when the drawing is exported for translation.
Text in symbols cannot be exported for translation.
To exclude a text object from translation
Back to Top
1 Using the Pick tool , click the text object you want to exclude.
2 Click Window Properties.
3 In the Properties docker, click the Summary button .
4 Disable the Include text in translation check box.
You can get the word count of a selected text object by clicking the arrow button located at the bottom of the Summary area of the Properties.
To import translated text
Back to Top
1 With the drawing open, click File Import translations.
2 Choose the folder where the XLIFF file is stored.
3 Click Import.
